where to buy gate rollers?
  • where to buy gate rollers?
    hello everyone! ask ko lang if any of you guys know kung saan nakakabili nito.
    out of stock daw yung seller sa sulit... im making a sliding gate kasi and i need the rollers next week.
    thanks and more power PHM!
    Re: where to buy gate rollers?
    Hi mnmc10,
    Visit Screw Kingdom and To Suy shops along Masangkay and T. Alonzo (Recto side). You may google for the map and contact #s.
    Good luck on your hunt and update us of you haul
      thanks to suy is behind arranque i think.
        The screw supply shops is around T. Alonzo, Recto, Tomas Mapua, Soler area.
          I haven't come across that item you need, either at to suy or screw kingdom. I suggest you alot a day to walk around Binondo in search of one...
            Don't know if this will work. When I did a pair of sliding doors for my house, I used a pair of of tensioning pulleys used in car aircons. Its used to tension the belts for the compressor. Readily available in car aircon supply stores. It doesn't have the support bracket of the one in the picture, but those can be built flat bar steel. It also has a built in bearing in the pulley.
              thanks sir timber! this will be a whole day expedition for me. i will also try stores that sells casters and those egg crate wheels.
              workbench,
              the tensioning pulley seems like a nice alternative. but as much as possible a round or triangular guide rail is best cause it naturally repels dirt and small stones on the floor. a flat or canal like guide will just gather debris and will need daily sweeping.
              i already asked a machine shop if they can fab a piece for me. but they said its hard to make a half moon roller. the best they can make is semi triangular or a spool like roller.
                Instead of looking for such rollers look for these roller bearings instead
                OR
                You can use two rollers in perpendicular so they would create a "V" groove which is just similar to what you use instead of a half circle like what you use.
                • Warren Duran
                  Warren Duran commented
                  Editing a comment
                  where can i buy this item?
                thing is i already bought a 3/4 gi pipe. thinking that the half moon roller is readily available.
                if i use the v type roller as sir jarod suggested, hindi kaya the v roller might eat through the round pipe? since hindi sila lapat sa isat isa?
                a friend of mine who is a purchaser for a machine shop goes to ongpin all the time. according to him what he usually sees are v or spindle like roller. he never saw the half moon design.
                thanks for the suggestions and i might just wait for the seller in sulit to get stocks.
                  ^Or you might try visiting the shops yourself. That way, you will not be bounded by a single supplier and you get to know other shops that you may need to visit in the future for other items. If the hardware shops fail, visit the bearings centers.
                  Bring a picture of what you need. They may have alternative at par or better than what you need.
                  All you need is a little time and effort and you will never go home empty handed. There are a lot of good Binondo eats to keep you searching
                    @ Sir Jigs - regarding on your requirement the latest is on monday sir...i will contact you when the stocks are available ok? just keep in touch nalang...
                      Good day PHM,
                      Any help san po ba nakakabili cantilever gate roller and accessories?
                        Tristan,
                        Try going to Binondo area or try Evangelista street in Quiapo, the street is full of industrial shops, left and right, simply ask around, I'm pretty sure you'll find what you are looking for.
                        Good Luck !!
                          San supplier or nabibili lang Sliding gate rollers or wheels and tracks
