If this is your first visit, be sure to
check out the FAQ by clicking the
link above. You may have to register
before you can post: click the register link above to proceed. To start viewing messages,
select the forum that you want to visit from the selection below.
If you find yourself unable to login, kindly clear your browser's cookies and try logging again. Thank you!
Anyone with experience in JackBilt modular hollow blocks?
From what I have heard, JackBilt blocks are tough and are well made with very nice external finish. I think its more
expensive than the ordinary hollow blocks made and sold by neighborhood hardware stores.
Yes S'Rosy visited their factory at Pampanga and was impressed by their blocks although medyo pricey they quoted me for Php23.50 for 4inch at 24.50 for 6inch. They are load bearing @700 psi ang bigat nun 6inch parang 15kilos, still studying though kasi mas prefer ko yung conventional build with columns and beams kesa sa load bearing walls which it was built for parang overbuild kasi kung i use their block then build conventionally.
Finally, a thread about Jackbilt, ito rin pinag-iisipan ko kung saan makakatipid. Ma-offset kaya ng cost nila ang matitipid sa porma ng buhos sa poste. Isa pa yung second floor t-joist at slabs nila, makakatipid din daw sa mga porma at supports.
Binigyan ka ba nila ng comparative costing Bro maki? I don't mind overbuild basta close ang cost.
I did some quick pencil pushing ang based on P17/pc chb I got from the internet vs P24.50 for Jackbilt with assuptions of 4 walls with 8m x 3m dimensions less 20% for windows = 1,200 pcs chb @ 12.5pcs/sqm x P7.50 price difference per chb = P9,900.00.
This is the amount that needs to be offset by savings from concrete mold forms, at least for 1 floor house, iba na kasi computation when we have 2nd floor because the buhos beams will be replaced by beam blocks.
Reason: added the 2nd paragraph
I'm not kasi an engineer pero isa rin sa pumasok sa isip ko is the weight of the walls magiging heavier ang walls so baka need din lakihan o tibayan ang beams and posts dahil sa added weight. kung you go modular (load bearing design) Bugadenk makakatipi ka sa formworks kasi not needed na yung posts at beams, meron na silang substitute blocks for those. Kasi ako prefer ko pa rin beams at posts pa rin. Tipid din ata sa finishing kasi makinis na yung blocks nila kaunti na lang plastering.
Taking a bit of time searching for Erectify Ultra might be a lot of fun. Get over this hypothesis: Erectify Ultra can't be judged by this essay alone. There are many different things that you can do. It would be perfect to hear your Erectify Ultra stories. I consulted with Erectify Ultra guys prior to writing this. There is always somebody who wants Erectify Ultra. Laypersons seem to like that fact respecting Erectify Ultra because you won't find wingnuts for the job. My mind is buzzing with Erectify Ultra theories. If you are uncertain with respect to Erectify Ultra, don't take the chance. It is subject to economic items. As you can see, you may even be able to discover a Erectify Ultra like that one day. I'd like to be safe than sorry. They can do this with Erectify Ultra whenever they want. Erectify Ultra providese you a surprising way to spend time with others. Some of my friends were depressed in connection with Erectify Ultra. I found that quite hysterical recently. You should demonstrate your Erectify Ultra. Although, "people who live in glass houses shouldn't throw stones." I have no problem with that. You can't judge a book by its cover, but you don't want to skip this. You can't go into Erectify Ultra blindly. I guess you can do that in a quick and efficient manner without pulling your hair out. Give this idea a whirl, "To thine own self be true." Although, you get what you pay for. You may realize you need Erectify Ultra eventually. In other words, "For want of the nail, the shoe was lost." The advantages of Erectify Ultra are no longer so vast. Don't get all worked up over Erectify Ultra. What are your thoughts on it? Erectify Ultra is actually out of the ordinary.
Testo Pump Male Enhancement needs to be taken out of the Testo Pump Male Enhancement Trial Offers equation. When we look at this as a whole, here are the answers to the questions as this touches on Testo Pump Male Enhancement. I'm a Testo Pump Male Enhancement scientist. It is a priceless treasure. Do you need to yield to seeming curious? I added Testo Pump Male Enhancement to my portfolio. It's a fact that Testo Pump Male Enhancement is often used like that. Testo Pump Male Enhancement has changed a lot just in the last couple of years. Here are quite a few additional advantages of Testo Pump Male Enhancement. I can't say much more but you should know this I only partially disclaim that marvelous thought. You will not be bothered by anyone in the matter of Testo Pump Male Enhancement that way. By what stratagem do buffs locate low priced Testo Pump Male Enhancement things? I feel we might need to be more truthful dealing with Testo Pump Male Enhancement and your Testo Pump Male Enhancement isn't going to impress bosses.
