RT in all weather
  • RT in all weather
    I want to built a long lasting RT table that can stand in all weather wet or dry at my rooftop hehehehe
    I bought a granite slobe at wilcon builders 60 x 90 cm for my bathroom but giving me an idea i want to make something different to my RT i hope it works if not hehehe for bathroom na sya making a slob for my labatory .......something to be done and prevent like chipping during cutting and radius at corner for RT plate that can fit perfect..... hehehe thats my wip
    Doc.violine has an aluminum RT and others made MDF RT and plywood for me hehehe granite router table weeeee
    update ko na lang ito for my new project....
    Re: RT in all weather
    I bet that cutting the hole for the RT plate would be the major task here. Looks good to me .... granite top RT.
      yap jay major major nga ito but offset cutting ang gagawin ko dito and then trimming the edge try ko muna sa scrap na granite and then get some idea to make a better result before i proceed to my table maybe this weekend masimulan ko na ito...I bought a diamond disk for my grinder ultra thin cut ..
        Subscribing, I also plan to have a granite slab with a hole for my kitchen island project.
          subscribed too..
          will carbide tips work on granite?
            naku i will subscribe to this build!
            naaamoy ko...ryobi will get a cnc machine to rout the recess for the plate and t track...
            ibang level kana bro!
            no room for mistake here...well at least the minimum.
              oh my goodness carbide tips wont work on granite. as far as i know only diamond tip grinding wheel will work.
              oh Ryobi, Granite Dust is nastier than saw dust... naaaaaaaaaaaaaasty. be careful pare
              forgot to add, granite is porous.. VERY porous, grab a PYE sealant to keep stains away
                @ bee
                hey nice to hear you hehehe thanks for the advice and tips
                @doc v.
                hi doc no modification to my router plate and t track hehehe your are right no room for mistake minimum lang weeee well it works hehehe
                @ moji
                carbide tips will not work @ granite magbabaga lang ung carbide tibs Bee is correct only diamond tip grinding wheel will work.
                @ jarod
                yap perfect for a kitchen island hehehe
                here is my update update
                same thing what we were doing making a router table on MDF or Plywood put a musking tape for marking for the router plate to make a perfect hole..
                  diamond disc ultra thin cut 495.00 pesos @ wilcon
                    here is my grinder modified with base .....I got this to my old circular saw SKIL its already defective due to burn motor so chop chop na hehehe
                      and then place a fence just to make it straight and start and end limit
                      here is my cut @ inner square lane
                      a closer look fo thin cut and check for chip out well its good for now
                      more closer hmmm i wish i have a good camera like doc violine have hehehe
                        and now for the outer lane oppppss wear safety gudget like safety glass mask ear mups gloves and long sleave to prevent granite dust anyway since I`m working at my rooftop and the weather was fine yesterday and windy so granite dust flow away weeeee hehehehe
                        change the blade for much thicker
                          10 times grinding @ one side
                          now I`m done for rubbeting it`s take 2hrs on grinding .....now full cutting @ the center to make a hole
                          here it is
                          tsk tsk kailangan talaga bumili ng bago camera hmmmm
                            and now the challenge is curve corner
                            remove the grinding guard much more flexible on grinding wear Safety Gudget
                            try to fit the router plate perfect hehehe
                            and now complete the four corner
                              eto na
                              done na weeee later na ung T track gawin ko muna ung table hehehe para safe ung granite table
