Bandsaw build
  • Bandsaw build
    The plan
    wheels
    bearing attachment
    wheels with bearing
      cut out the wheels using Maktec router trimmer MT370 form MDF
        finished wheels
        use a router to create the grove on the center then spray with sanding sealer.
          cut out 4pieces 1/2 inch mdf for the body of the bandsaw.. it will glued all together.
            bandsaw specs will be... 14 inch capacity
            any inputs in the build will be highly appreciated... specially those who has an orginal bandsaws at their shop.
              update...
              rough cut on the 1/2 inch MDF
              routed for final shape of mdf
              routed 1/2 holes for the mounting of wheels
                half of the hole routed on the MDF
                clamp clamp clamps... 4 pieces 1/2inch MDF
                  test fit of motor mounting... i will be using a water pump motor... but the problem is it is turning in the wrong direction. so i will be mouting it on the left side instead of the normal right side.
                    Nick, ngayon ko lang nakita to, I hope the 2 inches MDF body can hold the tension...delikado bro. Before proceeding take time to test it by sitting on top of the body then check kung nag bow by measuring the height before and after sitting on it. This was the advise to me by Matthias Wandel but my massive 4 1/2" bandsaw body was strong enough to resist bowing during the test and when tensioned. Baka mag crack ang gilid, try to find a way to re-inforce it with square bars masyado malutong ang MDF, delikado Nick.
                      @ Armand
                      medyo malambot pa nga ang 2 inches thick na MDF... kaya ginawa ko nilagyan ko ng 1.5 x 1.5 inch na angle bar support sa likod... pagkalagay ko ng angle bars tigas na nya.
                        initial mounting ng wheels
                        initial testing with motor
                        after initial testing... found that the upper part of the bandsaw is vibrating around 3mm... so I placed a 1.5 x1.5 inch angle bars for support.
                          Wheels with tire....
                          with angle bar support
                          inalis ko muna yung isang v pulley papapalitan ko masyadong maluwag sa shafting.
                            Just an update...
                            working na pala tong bandsaw ko pero wala pa syang cover sa wheels
                            my first project on the my bandsaw
