USB External Hard Disk drives
  • USB External Hard Disk drives
    good evening.
    patulong naman po. paano mag assemble ng ganito? bibili ka lang ba ng surplus laptop HD and usb HD enclosure? tapos kabit lang? o me mga hinang pa.
    plan to buy sana, pero parang mas masarap kng DIY e.
    thnx
    Re: USB External Hard Disk drives
    You just buy the hard disk enclosure and install a hard disk in it, no soldering required.
    You can buy the 2.5" version (laptop size HD) or the 3.5" version (desktop PC size HD). Yung 2.5 version, normally wala ng separate power supply. On the otherhand, the 3.5 version normally comes with an external power supply.
    Hope this helps.
      thnx for the reply. what abt the term ide or sata? ano nman yon?
      also the 3.5 enclosure with power supply you mentioned, kasama na ba power suply sa enclosure ? i separate ko pa bili
        sata are for desktops, usb ide ang ginagamit, instead of buying separate power supply, you can use old computer power supply AT, kanya lang bulky.
          Kasama na ang powersupply when you buy the usb enclosure. IDE and SATA are different hard disk interfaces. SATA is faster than IDE. You should look at the technical specs of the usb enclosure, some support ide while others support sata. If you have an IDE compatible usb enclosure, then you have to purchase an IDE hard drive. Likewise, if you have a SATA compatible usb enclosure, then you have to purchase a SATA hard drive.
            thnx for the tips...
            shoping na ko
              bili ka na lang ng pang laptop na HDD para mas portable & no power brick to worry about
                It's a very useful device and can be used with different platforms as PC, consoles and http://www.ps4storage.com/ps4-hdd-upgrade-guide/ so you can use it in different circumstances and be good.
                  USB external hard disk drives are working best right now. If you work at the http://therebelchick.com/this-is-wha...in-your-essay/ site, these external hard drives will work great for you, and will be helpful.
                    https://iprice.vn/gia-ban/ugreen-us121/
                    https://iprice.vn/gia-ban/ugreen-us115/
                      Thanks for the nice blog. It was very useful for me. I'm happy I found this blog. Thank you for sharing with us,I too always learn something new from your post. free youtube dislikes
