Where to buy Load Resistor
  • Where to buy Load Resistor
    this is how it looks like.
    may nakita ako ubod ng mahal 700-800 peso. looking for cheaper.
    Re: Where to buy Load Resistor
    If you're only after the values (resistance and wattage) and not the look, there are white bricks available at Deeco.
      My guess its for 12v led light for bulb as current limiter right? 50w 6 ohms load resistor designed for use in common LED for car right turn signal or brake thus preventing..If that so there are lots of it in Banawe..Cheers
        my turn signals hyperflashing too, nakakuha ng idea kay sir joey, might get those bricks at deeco and slap some old chipset heatsink in it, ma-diy pag may time.
          yung ceramic type wala yata sila ganun value. but not sure..
          btw any one have tried ceramic type load resistor?
          yes ill be using it for signal light ang break light
            Try DEECO. in Raon and Cubao and several other outlets
            Do you know how to wire in series or in parallel to change the resistance and/or wattage?
