what brand of aircon would you recommend?
  • what brand of aircon would you recommend?
    what brand of aircon would you recommend? yung affordable at energy savings at saka madaling linisin by your self... thanks
    Re: what brand of aircon would you recommend?
    window or split type bro?
      Depends on the size of the room.
      Just about all the air-con units are built with the same or similar quality. The added on features and of course the economy rating is important.
      If window type, be sure there is a timer built-in. Some even have a way to connect an electric fan that kicks in when the air-con shuts down.
      Check your warranties and locate the service centres.
      I don't think the split types have this timer, not sure though.
        meron din timer ang mga split type bro.parang standard feature baga.
          go for carrier or condura....
          mga institusyon na yan sa aircon
            yung window type. what size ba dapat bilhin ko ang size ng room ay 12x12 ft.
              go for the 1hp.super lamig nayang room mo sabayan mo nalang ng electric fan after lumamig ng buong room
                If you are on a budget, the .5 or .6 hp air con units will be sufficient, but the real cheap ones don't have a timer. The locally made units like Condura have the most number of service/warranty centres, but are slightly more expensive then the LG or Samsung equivalents.
                Makro units are the cheapest, but some real unknown brands.
                  Para makatipid sa koryente, I suggest that you consider the highest EER rating for similar power ratings. Say, if you have decided to get 1hp (the rule of thumb is 1hp for every 20sqm room space), compare and get the highest.
                  For cooling comfort, I suggest you compare and consider getting the highest BTU rating because some 1hp a/c have 11,000BTU, while some have lower or higher than that. Get the highest for the same power rating.
                  But of course the higher the BTU, the colder, the higher its energy consumption or the lower its EER, as the basic principle of equilibrium applies; that is, energy in = energy out. More electrical energy going in necessarily gives you more cooling energy.
                    I like Panasonic aircons for their quietness.
                      mine is a 3/4hp na samsung, it's been with for 10yrs. na, so far no problem, w/ timer, base on experience minamal ang additional sa electric bill, ako mag-isa kayang buhatin for cleaning, kanya lang wala na ako makitang the same, dati i bought it for 12T @ 1,000/month zero interest on card. regular maintenance lang.
                        Both our aircons are Condura and they've served us well for about 10 years now. My recommendation is to get the largest unit, within reason, that your budget can afford. By doing so you make it easier for the a/c to cool the space, reduce the wear on the unit, and in turn prolong its lifetime. I'm not sure but I think efficiency also improves with size.
                          I have a GE 3/4 with electronic thermostat with temperature readout. It's doing fine and saving me money. I've turned the thermostat to the highest comfortable temperature which for me and my wife is 25 degrees celsius.
                            Condura user here for years. No problems so far. Happy with performance.
                              Recently installed a 1.75HP Panasonic Inverter Aircon (Split-Type). Comes with air purifier/ionizer. Very quiet operation and low energy consumption as well.
