Health Hazard Asbestos
  • Health Hazard Asbestos
    Hi, Everyone. I have this old Oven that I've been using quite some time, and recently out of research I bumped into this site that says that ovens contain fiber of asbestos material that reduces heat when using your oven. it is of yellowish origin and it is dangerous to health at it is carcinogenic.
    After reading I checked the layer of my oven and in deed it is of yellowish fiber and i'm having allergic reaction to the material.
    Definitely I will remove this Asbestos material, now my question is:
    What is the best material or materials that contains no carcinogen,
    w/c could withhold or stand the amount of heat as an alternative to asbestos
    so that I could still use my oven. and Where could I purchase that material or materials.
    Thank you
    Re: Health Hazard Asbestos
    Welcome to PHM, donpigado!
    What's the brand and model number of your oven? When was it manufactured? And please post some pictures.
    It might be fiberglass but its better to err on thenside of caution. Found this on another forum. You two have the same problem.
    http://www.chemical-forum.com/thread-153989-1-1.html
    BTW please do tell us more about yourself in the member introduction section.
      Try using fiberboard like hardiflex, it should do the trick.
        Yes, and what kind of allergic reaction do you experience? Loose fiberglass, when it comes into skin contact, causes itching, not because of allergy, but because the tiny glass shards pierce your skin.
        Also, if the asbestos is properly sealed, it may be best to leave it alone. Asbestos is carcinogenic if you inhale it. Asbestos removal and disposal is best done by professionals. You don't want those unseen fibers floating in your kitchen when you tear off the lining.
          I didn't get. Asbestos isn't banned still? It's proven to be cancerogenic. Why is it still in use? That's so strange. Tell you what, visiting doctors wouldn't go amiss. But that's about serious health threats. For example, if you need some medicines to cure ED or you are looking for generic don't shy to visit Canadian Health Care Mall. Here you can find a big variety of different medicines to cure lots of diseases.
            Asbestos-containing machines are very common to use in our houses.
              I will say this to you, I have been working with asbestos for a long time, and if I had listened to my wife in time and left work, I would have no health problems. Now I have to use Viagra https://pde-5.com, you know for what. Also, constant pain in the lungs is a very harmful medium, immediately get rid of it.
