Frequency converter for 50hz 220v gas range
  • Frequency converter for 50hz 220v gas range
    Where can i buy a 50hz to 60 hz frequency converter or inverter ? Nakabili po kasi ako ng wansa gas range 80x50 220v 50hz. So far ung manual ignition lang nagagamit at di pa nagagamit ung grill at oven baka kasi masira ung timer at thermostat dahil 50hz lang frequency nya.
    Renjc, there was an old thread here in PHM about 50hz and 60hz and one of the replies mentioned that in most products built now, it can handle both 50 and 60hz without any problem as what some techincal persons are saying. the only way to prove this is to email the manufacturer with the question :-)
    before buying the frequency converter, it would be better to review the technical specs of the unit if you have one and also send an email to the manufacturer about your question. just make sure you constantly make kulit to the manufacturer for a reply to your email (this is based on my experience, like i make a followup email every week for a reply until they reply) ... cheers
    • Renjc
      Renjc commented
      Editing a comment
      Thanks Boo but i think it would affect the timer and the thermostat anyway i will try to verify from wansa if it can run on 60hz without affecting the electronics parts.
    Hi...any devices that are 110volt but not 50hz/60hz sensitive. In our case waterheater, watermark pump, Dolphin charger. These devices will run fine with only a transformer. (Note, hear is probably where we overdesigned the transformer because we don't need to be able to run the watermark while in port. A smaller transformer would have been cheaper, lighter, smaller) Note: all of these devices are on LINE #1 of our two 120v lines. The transformer only needs to supply TRANSFORMED power to that one leg. I think you can get transformers that have two 120volt outputs if you need power to both LINES.
    heavy copper pcb
      for the frequency converter, I suggest
      https://geeksquadtechsupport.co/ they are best in online services for any product I think it is good to purchase from there i also ordered a converter its working good.
