Sand, Gravel & Cement Smart Mixing
  • Sand, Gravel & Cement Smart Mixing
    Does anyone of your here knows the right mixing ration for sand, gravel and cement? My brother is making some maintenance at home and we don't know the right mixing amount.
    I tried to call our uncle but this Smart don't have thier freaking stable signal. You just get connected for a few minutes minutes and disconnected for almost an hour.
    But anyway, anyone have an idea?
    Re: Sand, Gravel & Cement Smart Mixing
    Here is the ratio of Cement:Sand:Gravel
    Column and Footing - Class A (1:2:4)
    Concrete Hollow Block Footing - Class B (1:2 1/2:5)
    Reinf. Concrete Slab & Beam - Class A (1:2:4)
    Slab on fill - Class C (1:3:6)
    Example if I'm going to pour concrete on column. I need the Class A Mixture that requires (1:2:4) ratio.
    A 40 kg Bag Cement is approximately 1 cu.ft. You need 2 cu.ft of sand & 4 cu.ft of gravel for the proper mixture. We just used the empty cement bag for sand & gravel ratio. Simply 1 bag cement, 2 bags sand & 4 bags gravel. Then clean water to make a pliable paste.
      Ngayon alam na natin yun tamang mixture.
      If I'm going to pour concrete on 2 columns with size .3m x .3m x 3m height. How many cement, sand and gravel do I need.
      Simply compute the total volume = .3x.3x3 x 2columns = .54 cu.m.
      For class A Mixture
      CV (Concrete Volume) x 7.85 = No. of cement = (.54x7.85) = 4.2 or say 5 bags
      CV (Concrte Volume ) x .42 = No. of cu.m of sand = (.54x.42) = .23 cu.m Sand
      CV (Concrete Volume ) x .84 = No. of cu.m gravel = (.54 x .84) = .46 cu.m Gravel
      Add 10% allowance for wastage.
      Hope this will help you.
      • ce.esn25
        ce.esn25 commented
        Editing a comment
        Sir, yung reference po ng cement dito per bag, 40 kg or 50 kg?
      • Boo-Semi-Retired
        Boo-Semi-Retired commented
        Editing a comment
        in PH, most of the cement are sold in 40kg bags ... cheers
      • Pirsan
        Pirsan commented
        Editing a comment
        Sir, magtatanong po sa ako kung anong specific store ang merong class c portland cement?
      sir beginners question
      1. kung yung hump lang po sa garahe na may wash out, puwede po bang wash out sand and cement lang ang mix at ano po yung ratio?
      2. butas po na tatabunan ng cement at gagawing daanan , ano po ang ratio ng cement sand at gravel?
      thank you po
        Hi there bro custom888
        Bro answers to you two questions will depend on how long and wide will the hump be and the hole you intend to fill up or cover will also depend on how deep and wide the ground hole but basically you can base them all mixing ratios in sir bryant77's reply.
        GOOD LUCK !
        BTW, this is a bit OT here, could you kindly introduce yourself in the MEMBER INTRODUCTIONS, since you are a newly registered member here. Can you give us some information about yourself and what do you usually DO as a DIYer, we'd like to know you better as a new member.
        Thanks,
          a bit of OT here, are those Additive Mixture that claim to strengthen the concrete, do they really live up to their promise?
            how many Cubic ft can this mix produce?
            how many Water do i put?
            Thankx
              Class C (1:3:6) Concrete Mix
              CV x 5.49 = No. of bags cement
              CV x 0.44 = No. of cu.m. Sand
              CV x 0.89 = No. of cu.m. Gravel
              Water to make a pliable paste.
                Thankx sir Bry
                ask lang fix value ba yung 5.49 , 0.44 , 0.89? if sa Class B anu value niyan?
                  May tanong lang po ako sa mga masters dito. . .
                  Ano po dapat gamitin for wall finishing? Rough kasi masyado ang walls. I was thinking perhaps we can create a wall finishing for it. Thanks po.
                    Hello po...
                    Gagawa po ako sanan ng Hollow kaso hindi ko po alam kung ano po ratio ng isang bag ng cement vs sand? anyone knows how? and the ratio of the sand and cement
                      Hello po...
                      Gagawa po ako sana ako ng Hollow Blockl kaso hindi ko po alam kung ano po ratio ng isang bag ng cement vs sand? anyone knows how? and the ratio of the sand and cement
