Tiles brand
  • Tiles brand
    Ano po ang magandang brand ng tiles for flooring, kitchen and comfort rooms?
    Ung mga nakikita ko sa hardware mostly is yong Mariwasa, eurotiles, italy, etc.. Ano pong maganda dun.? Please suggest if merong much better. thanks..
    Phils. Exam Resuts - www.examresultsph.com
    Re: Tiles brand
    i dont think you will get a definite answer here.
    BAscially philippines now has a regulation that tiles have to have a certain standard. I think compressive and tensile strength. If any sort of tile does not pass the standard then it is not allowed to be sold. So when it comes to durability dont worry.
    in a nutshell. Italian tiles are top notch, followed by spanish, then indonesian tiles. China tile are a bit complicated to rank. because brands like Lola (wilcon) and sol ceramica (wilcon depot has this also) can pit against spanish quality. These two brands are the ones i used in my house. I also have other spanish tiles scattered in the house. All of which i think i got from wilcon since they have a good assortment from budget to luxury (tinitigan ko nalang hehehe)
    So to be honest you have to come down to budget and design. and remember ALWAYS use TILE ADHESIVE not cement (i learned the hard way) Tile adhesives are formulated specifically to hold something to the wall... cements are not. if using cement and it did not cure long enough it will eventually let go of the tile (you dont want this on your wall) while tile adhesives are very much forgiving and will ensure that your tile will stick to the wall for a lifetime. and and with cement... you can crack your tile over time.
    • Mae
      Mae commented
      Editing a comment
      Hi po, okay po bang haluhin ang tile adhesive with sand?
    Re: Tiles brand
    Thanks for so much info.. Oh, i haven't heard the TILE ADHESIVE, our canpenter I think prefer to use cement. Tiles are on the flooring though... I think its ok..
      Re: Tiles brand
      If you will be installing granite tiles, especially those that are made in China, it would be better to use tile adhesive. Otherwise, after a few months, you will feel some tiles moving already.
      For ceramic tiles, cement will do but tile adhesive is still better.
      But whether your carpenter is using cement or tile adhesive, supervising their work is still very important. Tiles usually breaks or peels off easily when not installed properly.
        Re: Tiles brand
        sorry for being out of topic here... just want to ask if there are other colors available to be used to color a flooring. I think they call it colored cement. mostly the stores i ask the only available color is green or red.
        Is it ok to paint your floor with rubberized paint so that you can have the color you want for your floor. thanks.
        and sorry again if im out of topic.
          Re: Tiles brand
          for tile adhesion, they do have colored grout (similar to white cement)...
          bought a tile way back at Wilcon, they sure are nice... made it to a table top for the kitchen.... lol
          sorry to be O.T.
          cheers
            Re: Tiles brand
            Ung china ba na granite ok lang ba. tumatagal din ba.
              Re: Tiles brand
              yes tumatagal... matagal... granites regardless of its origin will last pretty much forever (natural granites)
              but these have to be sealed with masonry sealer to keep its appearance top notch. Sealing has to be re done every few years or so. More often if outdoors
                Re: Tiles brand
                now a days anong magandang tile pattern
                  Re: Tiles brand
                  if on a budget go for the local tiles like mariwasa and eurotiles. just make a pattern or motif to make it nice. get a 30x30 size or bigger cuz mas impressive.
                  if may budget ng kaunti go to mc and ortigas home depot, wilcon, kuysen,dexterton. they usually have good quality tiles on sale but limited quantity...so ok lang if your requirement not so much.
                  if sky is the limit go to decimal,prime,home studio,goldkeys, grupo armani...marami pa that escapes my memory.
                  floor center if you like cheap good looking tiles but in terms of quality not all tiles are ok.
                    Re: Tiles brand
                    ITALIAN tiles will be best one they have best tensile strength and durability . I am giving advise to you on the basis of my personal experience.
                    _________________________
                    Kitchen Renovation Contractor
                      Re: Tiles brand
                      Italian ceramic tiles are best for flooring and walls and use best tile adhesive. Always use durable and long lasting tiles.*
                        Hi, I am looking for black floor tiles with glitters (nagsparkle yung glitters with light). Any suggestions where can i possibly buy it? Thanks
