[H] Paano po pagpaint ng wall?
  • [H] Paano po pagpaint ng wall?
    Bagong tayo lang po bahay namin and i decided na i-DIY nalang pag wall paint...
    alam ko po na need pa lasunin ung wall before painting...puede po bang makahingi ng instruction paano pag wall painting..
    Pure rock (semento) po ung wall namin..ano po bang maganda panglason? anong brand? ilang araw paglason bago puede ng patungan ng pintura... ano po ba ung pang primer na pintura?
    Re: [H] Paano po pagpaint ng wall?
    I am in touch now with Davies paint and confirmed a seminar with them on June 26. they will teach us how to properly do this kind of thing, If you can wait till that day, I suggest you join. they even have a software wherein you can color your house from a picture even before buying a drop of paint. so you can have an idea how it would look before you paint it.
      thanks you po sir pero busy po sa work...pwede po bang bigyan nio ko ng konting tips ..kahit basic lang po...
        painting cement walls is not my cup of tea. I am not the best person for this. I am sure someone will reply just wait ng konti. goodluck.
          u lang osana o may magshare..need ko o kasi talaga ng advice e...
            For Interior concrete walls I usually do as follows:
            Neutralize with Boysen conc. neutralizer(any brand will do)
            Wash off crystalline deposits
            Prime with flat latex
            apply appropriate putty(either flat latex with patching compound or gypsum putty)
            sand until smooth, re-putty if necessary.
            apply 1st, 2nd and final coat of latex paint.(lately being fond of using sun and rain products)
            for exterior applications:
            prime with boysen acrytex primer.
            putty with acrytex cast
            sand until smooth
            finish with either acrytex top coat, semi gloss latex or any exterior elastomeric paint.
            HTH!
            GACA CONSTRUCTION
              hehehe, tagalog, english and abbreviated words are great to use, please try to avoid lang posting as if you are texting on your phone... unlimited characters dito and free pa, so please avoid text speak.
              hantay mo lang kasi weekend, people tend to go out of town especially during long weekends....
                there you go, thanks opzuk...
                  sige sir wait ko rin ung instruction mo...sorry ho sa sa abbreviated words but hindi ho abbreviated words yan..sira lang ho ung letter p dito sa keyboard ko..
                  sand until smooth
                  HTH!
                  thank you ho sir sa instruction...eto ho follow up question ko..
                  ilang days po ba papatagalin ung neutralizer bago pinturahan ng primer
                  puede na po ba dito na water lang pang wash o water lang talaga pangwash dito
                  after po kasi ng white flat latex na primer e plan ko ipaint ng ibang color...sa mix ng paint para sa color ano po ba ginagamit na paint na pang mix ...puede rin ba ung flat latex na pang mix sa colored paint....
                  tsaka para saan po ba ung sun and rain products....ngaun ko lang po kasi to narinig...
                  more power !!!!
                    more power !!!!
                    Usually in 2-3 days pwede na hugasan ng tubig.
                    For latex paint only acri colors should be used. Your finish coats can be flat, semi-gloss or gloss latex.
                    Sun and Rain is an elastomeric acrylic paint available pre-mixed with a variety of colors. I like it as it is in my preferred "egg shell" finish.
                    GACA CONSTRUCTION
                      ibig po bang sabihin after ko i-neutralizer ng 3 days ay need ko pang i-wah ng water ung wall/pader bago ko patungan ng primer?
                      meron na rin po ready mix na paint na hondio na kelangan mag mix? ano po brand? thnaks
                        Yes. There are a lot of ready mixed interior and exterior paint available in the market. There is sun and rain, rain or shine, davies bio fresh and a whole lot more.
                        GACA CONSTRUCTION
                          Good day sir!
                          If new concrete, kailangan ng 14 to 28 days na curing time bago tayo magpintura. (Kailangan ito para lumabas ang alkalinity ng semento at maiwasan ang mapa-mapa pag nag-apply na tayo ng pintura.)
                          Tapos nito, pahiran ng Boysen Masonry Neutralizer #44 para lasunin ang semento. Huwag purong neutralizer and ilagay. Kailangan 1:16 lang ang ratio ng neutralizer sa tubig. (Halimbawa: 1 litrong neutralizer sa 16 litrong tubig)
                          Patuyuin overnight. Mapapansin mong merong mga white crystals na lalabas sa walls mo next day. Ibig sabihin nito nalason na ang konkreto.
                          Alisin ang asin (white crystals) sa semento sa pamamagitan ng tubig. Pag natuyo na ang semento pwde na tyong maglagay ng pintura.
                          1st Coat: Boysen Flat Latex #701
                          Putty: Boysen Masonry Putty (masilya)
                          2nd & 3rd Coat: either Flat Latex, Semigloss Latex or Gloss Latex
                          PWEDE RIN
                          Kung ayaw nang lasunin pwedeng gumamit ng Acrytex Primer instead of Flat Latex bilang primer. Pero kailangan pa rin ng curing time na 14 to 28 days bago magpintura.
                            Good day sir!
                            PWEDE RIN
                              sand until smooth
                              HTH!
                              Well said Po! pero po im not against sa boysen but marami pa rin pong brand na you could try
