Latex paint for plywood?
  • #46
    Pwede naman yan latex basta naka primer ng flat wall enamel yung plywood, batakan mo ng boral manipis lang para di kita grain ng plywood tpos 2 coats ng latex kahit pre mix. wag ka na mag acrycolor lalo na pag ka mga dark color dami ka gagastusin bili ka nalang ng pre mix mas ok di ka pa ma hasel mag timpla. ayan photos last project namin yung puti latex din yan kadalasan kasi yung enamel makintab kaya latex na ginagamit ko d naman nasisira kasi di naman mahawakan un.
    • #47
      bare plywood + rj putty + any acrylic latex paint = latex painted plywood!
      this is recommended sa mga items na hindi na hahawakan ng gagamit forever...katulad ng kisame...LOL
      • #48
        i'm kinda not sure if i understood this perfectly, correct me if i'm wrong (paint noob here).. i'm renovating my room and retained a wall made of plywood, while the rest is replaced with new gypsum boards. do i prime and seal both materials with stain halt, then i can coat it with boysen healthyhome color?
        • #49
          pepperpig, yes, you can prime and seal it using stain halt (now are rare entities at ACE), then coat them with any acrylic or latex paint, or even enamel...stain halt goes with anything eh.
          but there are primers now for wood which can take up acrylic latex paints..i am just not sure exactly about the brands but they should be available by now..spend time reading the labels at mall hardwares..
          • #50
            Sir violaine, just want to be sure if this would work kc plywood gamit sa wall/divisions:
            1st coat is to use BOYSEN Flatwall Enamel B-800
            Then seal with BOYSEN Plasolux Glazing Putty B-311
            2nd and 3rd coat BOYSEN Healthy Home
            Maraming Salamat! - Mark
            • #51
              Hi need advice.
              Anong primer for wood na compatible with acrylic latex
              primer for metal that is also compatible with acrylic latex
              or meron bang odorless paint for wood and metal?
              TIA
              • #52
                I was looking for the paint sprayer for my garage and I found this website https://usefuldiary.com/paint-sprayer-for-home/ selling online. I hope here really good paint sprayers are sold, see, I am ordering for the first time. Here are a lot of paint sprayers that is why it took some time to choose the one I needed. So follow the link if you want to buy the one for yourself.
                • #53
                  Originally posted by thejay View Post
                  Hi need advice.
                  TIA
                  Hi thejay. I believe flat wall enamel should do the trick since its's enamel-based with a matte [almost] finish. Its even intended to be used as a primer before applying putty and top coat [as per instruction from Boysen Flat Wall Enamel]
                  Just sharing, not sure if this helps...
                  I made a cabinet a few years back. Collapsible siya and the pieces [3/4" plybpoard] are joined together by black screws. Reason for using latex is for interior only while the outside is to be wrapped in vinyl sticker. Anyways, what i did was apply flat latex as first coat, sand it, glazing putty then sand it again. Lastly I applied 2-3 coats of gloss latex. The finish is almost the same as enamel and till now ok pa naman.
