how to intall euro hinges (suugestions/comments)
  • #16
    Re: how to intall euro hinges (suugestions/comments)
    HE HE HE HE, + 1 rin ako kay bro ricky for violaine' s replies.
    • #17
      Originally posted by imcnovicio View Post
      sir ok lang po b gumamit ng forstner bit and hand drill(dewalt) sa pag execute ng hole po kc wala po akong drill press?thx po
      I hope Timber & Doc V's previous posts gave you an in depth view of how you can work on your project even w/ limited tools and resources. Should you still have reservations or doubts just ask for instructional WIPS w/ PICS if possible and hope that some of our kind experts may lend you some of their treasured secrets on file. Good luck and Ingat.
      • #18
        Ok ok ok ok ok
        • #19
          Hahaha! Welcome to PHM, imcnovicio!
          Ganyan lang talagang magbiro ang mga tao dito. Mahirap kasi pag written lang, eh. Nawawala yung emotions. Pero pagkaharap mo ang mga iyan sa EB, tyak sasakit ang tyan mo kakatawa.
          Dito lang kasi nagsimula iyan:
          Originally posted by violaine View Post
          hindi naman madududurog yung plywood basta sharp at new yung forstner bit..maganda sana kung carbide tipped yung forstner bit mol..tandaan..madaling machoke yung bit kaya hinay hinay lang pag butas...angat lagi at tanggalin ang wood chips..
          ala pang 12mm yung depth nun kaya kahit free hand lang ang pagbutas mo eh ok na at hindi mo na kailangan ng drill press...siyempre pag madami kang bubutasan na door panel eh nakakangawit yun. pero hindi mo kailangan bumili ng drill press for that purpose..pagtiyagaan mo na lang muna.
          tandaan..ok lang gamitin ang drill press sa mga manageable projects like kitchen cabinet doors..
          longer than those eh awkward na ang drill press.
          mag experimento sa distance ng edge ng wood at hole to be sure.
          pero standard kasi yung mga soft closing euro hinges ko kaya i never go wrong sa 7mm distance.
          magpraktis!magpraktis sa scrap.
          pahabol..mas maganda nga pla kung variable speed yung drill...pero kahit hindi ok lang.
          mag ingat!
          Ako rin hindi ko nakita agad. I had to back-read. Hehehe.
          Enjoy the site!
          • #20
            Originally posted by timber715 View Post
            Basta ako, I prefer using a Bosch drill or drill/driver for that matter. Ang Dewalt kasi yellow, medyo nadidistract ako sa color na yun eh.
            even a manual hand drill will work and tama recommendation ni Doc V. you can use the bit as a reference for depth....
            AHHHHHHHHHH Ok color problem lang pala HEHEHEHEHEHEHE
            Editted: please try to avoid using capital letters bec it denotes raising voice or shouting. a friendly advice.
            • #21
              Originally posted by joey81 View Post
              hahaha! Welcome to phm, imcnovicio!
              Ganyan lang talagang magbiro ang mga tao dito. Mahirap kasi pag written lang, eh. Nawawala yung emotions. Pero pagkaharap mo ang mga iyan sa eb, tyak sasakit ang tyan mo kakatawa.
              I hope this doesn't drive you away from the community. Enjoy the site!
              k bro, salamat................. At pacencya na...... :d:d:d:d
              • #22
                i think i broke my promise.
                ehehehehe
                • #23
                  Look for Blum, Hafele or Hettich websites. There you can download catalogs and information about all their hinges. Good luck!
                  • #24
                    do you get tearing problems with a forstner bit on plywood?
                    • #25
                      tearing problems?
                      parang hndi..kasi yung blade ng forstner, parang kino compress nya yung wood fibers pababa..
                      pero i will try din to find out.
                      how about you axilla?
                      V
                      • #26
                        the only time i used it was with an expensive bit on pre made solid- wood doors (carpeneter brand iirc). i only found out later that cheaper forstner bits can be had at a tenth of the price, but in my limited experience a cheap talim saves you no money.
