Tips and Tricks Around the House
  • #31
    Re: Tips and Tricks Around the House
    Which part not clear? The idea is to measure the voltage at that outlet with your VOM as done before but with a light bulb plugged in. You can attach wires/plug to a light bulb socket or use an existing lamp. Incandescent so that it will still 'work' and not be harmed if powered by less than 220 V. If still not clear how to do this test or how to do it safely, best to wait for the electrician.
    • #32
      my problem was solved just today.
      my initial hunch was correct nga na one of the wire was cut off , but what makes it difficult to see is that yung way it was cut.
      the connection was from the breaker panel yun wiring is through the conduit pipes to my wall outlet then spliced to the outlet in the garage( eto yung no power ) , yun pagkasplice nung connection papuntang garage outlet e nabroken/putol na , kaya pala na me power yung outlet sa loob ng bahay but yun sa garage wala.
      in the end, i just decided to rewire the whole circuit na yun and used the gage #10 wire kasi ill be using it for my power tools and my welding machine so upgrade na lang .( thanks nga pala sa info ng wire size sir joey from cab1net kagabi )
      medyo natagalan lang yun paghugot ng wires kasi , some dirt/mud yata yun nagpasikip sa wire nung pinaliatan namin ng wire di makapasok e.
      ,thanks po uli sa input
      • #33
        Well bro, I'm glad to know that you have solved your problem regarding your electrical connection sa garahe. Hehehe, its, all is well that ends well.
        Now you can continue with your wood projects .
        CONGRATS BRO !
        • #34
          CONGRATS BRO !
          Thannks po sir Rosy .
          hehehe pause muna , exams week ng mga kids ko kailangan gumawa pointers tsaka revisions e
          pero resume yun mga gagawin ko after
          thanx again
          • #35
            My personal nightmare is having a wire disconnect or getting irretrievably snagged while pulling it out of the conduit.
            I'm glad you solved this.
            • #36
              Buhayin ko lang po ang thread. Effective palang pantanggal ng double sided tape at liquid nails sa wall ang WD40. Yun ang ginamit namin nung nilinis namin ang wall ng room ni baby.
              • Boo-Semi-Retired
                Boo-Semi-Retired commented
                Editing a comment
                pre, thanks for sharing this tip :-) ...
