How to repair small gaps in hardiflex board ceiling?
  • How to repair small gaps in hardiflex board ceiling?
    [original post was lost, modified by a spambot]
    It seems there are some movement sa pamakuan ng kisame. You can use gasa, placed in the areas with gaps
    by brushing with latex paint para dumikit sa ceiling, then let dry. Them apply a second coat of latex paint, again
    let dry over night before sanding. Tapos masilyahan ang surface to even out the area then sand again after it dries.
    Then apply your semi gloss latex paint sa ceiling.
    Hope this helps !
      my carpenter is using Masonry putty for the gaps, kasi yung iba ginagamit yung Polytuff but after a few months nabakbak agad.
        Originally posted by abbie
        I have not understood your language please use English language and home improvement damp surveys Hampshire is best for home renovation
        abbie, the site is located in Philippines, most often we post in English, ofcourse we post using our native language too.
          abbie,
          It would be nice for us all if you could give us some introductions being a new member of PHM. Are you a foreigner ? if so, then from what country are you from ? Below the PHM index page just under the Gazebo forum is the Member Introductions, kindly tell us what you do, or your hobbies or interests perhaps as a diyer, we'd like to know you better as a new member.
          Thanks.
            We might be talking to a bot here. A request to use English and a company endorsement in one sentence. If you can call that a sentence.
            And promoting a New Hampshire company in a forum where people speak a language she doesn't understand...
            abbie, you have 72 to convince us why we shouldn't consider your post as spam.
              Ano ba pinagkaiba ng BORAL at patching compound? Yan kasi pinabili ng karpintero nung nagparenovate kami. Yung kisame ginawang hardiflex at yung pader minasilyahan bago pinturahan. Di ko alam kung saan nya ginamit yang boral at patching compound. Nagpabili din sya ng mortabond skimcoat, yan yung nakita kong pinang masilya sa pader para kuminis. Ngayon nagpabili ako ng patching compound para pantapal sa joints ng kisame namin. Sinubukan ko yung patching compound ihalo sa latex pero di sya nagiging parang clay na pwedeng ipangtapal sa mga joints. Para syang evaporated milk nung haluan ng latex paint. Kapag dinagdagan ko pa ng patching compound nagiging dry na sya imbis na maging parang clay na pwedeng imasilya sa mga joints. Di ko alam kung ano ginamit ng karpintero para tapalan yung mga joints sa hardiflex at malaking cracks sa pader. Bumili din ako ng boysen masonry putty. Sinubukan ko pantapal pero nung nadry na sya numinipis sya kaya di pede pangtapal. Pampakinis lang yata yang boysen 7311.
