Any methods for repairing loose tiles without removing?
  • Any methods for repairing loose tiles without removing?
    Poor workmanship has caused loose tiles in a recently acquired building. I saw on youtube an adhesive product in the US that can be injected after drilling holes into the spaces between tiles and sometimes on the tiles themselves. Is the product available here? Would anyone know of a similar product or method that will repair loose tiles without removing them (and often breaking them in the process)? I am referring to 12x12 ceramic tiles, by the way. Thanks in advance for the help.
    I don't think there's the same product or service available in our country. If its poor worksmanship, you could contact the original contractor of the building and make them work for it. You could make them do that for free if you could prove that its caused by their poor worksmanship, other than that, fixing those spaces would require removal and replacing of tiles which is better and safer.
      Phendora Garcinia has yet to find a approach to her hassle, as evidenced by means of the fact that she continues to be looking, she is probable to maintain a bad view of just about any method, and in her determination that this new approach will fail as well, will act to make certain that it'll. In this case, if she has but to recognize the underlying causes for each her emotions, and her behavior, she is probably to avoid taking obligation for behavior, and as a substitute act to shift the duty to the approach itself. Blaming the technique for her lack of fulfillment.
      https://pilpedia.com/phendora-garcinia/
