Metals Price Updates
  • #61
    Re: Questions about metals...
    Originally posted by Fielster View Post
    Brethren, I would like help on the following regarding these:
    50mm x 75mm x 1.5 mm thick TUBULAR PIPE - ang ibinigay sa akin nung trusted naming metal supplier ay size 2x3 or size 2x4...
    75 x 75 x 1.5 thick ANGLE BAR - 1/4 at 3/6 ang ibinigay sa akin upang pagpilian? Malabo po sa akin...
    Any idea po kung anong eksaktong nomenclature nito sa metal suppliers?
    Hope you guys can help me out!
    Hmmm ako din nala buan......
    First things first .. what do you need
    1. Angle Bars
    or
    2. Square Tubes
    • #62
      Re: Metals Price Updates
      Sheet Metal ( Mild Steel )
      18 Gauge
      Full - 1,180
      Half - 600
      16 Gauge
      Full - 1,540
      Half - 780
      14 Gauge
      Full - 2,100
      Half - N/A
      • #63
        Checkered Plate
        18" x 20"
        360 pesos
        • #64
          a bit OT, what's the smallest square tubular (not square bar)? gauge? how much? thanks
          all i find near me are 1"
          • #65
            Here in my area the smallest i bought is 3/4 x 3/4.. Thickness ranging from 1.0 mm,1.2 mm the thickest i got is 1.5 mm..
            Been searching for 1/2 square tube but unfortunately can't find one..Maganda sanang gamitin for a simple magazine rack..
            3/4 x 1.5 price is 200 php in my suking hardware store..mas manipis mas mura of course..
            • #66
              Same here in our area, same size of 3/4" X 3/4" and going up are the size available. Just not sure if the 1/2" size you are looking for are available in the neighborhood hardware stores. Perhaps with stainless steel tubing, you will be able to find some.
              • #67
                Inquired price list from a steel manufacturer there in manila. Kudos to the sales guy who patiently listed the items I need to know - unluckily, he did not include the square/rectangular tubular. Hope this helps to those who also wanted to have an idea how much it costs for their intended projects in mind.
                p.s. May I suggest that those who have WIPs, when they list their materials, also include the price of each item? - just a suggestion.
                Deformed Round Bar, 8mm x 6M (1.9kls) 70.00
                1 pc Deformed Round Bar, 10mm x 6M g33 128.00
                1 pc Deformed Round Bar, 12mm x 6M g33 184.00
                1 pc Deformed Round Bar, 16mm x 6M g33 326.00
                1 pc Deformed Round Bar, 10mm x 7.5M g33 163.00
                1 pc Deformed Round Bar, 12mm x 7.5M g33 235.00
                1 pc Deformed Round Bar, 16mm x 7.5M g33 418.00
                1 pc Deformed Round Bar, 10mm x 9M g33 195.00
                1 pc Deformed Round Bar, 12mm x 9M g33 282.00
                1 pc Deformed Round Bar, 16mm x 9M g33 502.00
                Angle Bar, (1/ 2mm x 3/4 x 3/4 x 6M- offer only 235.00
                1 pc Angle Bar, (1/ 2mm x 1 x 1 x 6M 188.00
                1 pc Angle Bar, (1/ 3mm x 1 x 1 x 6M 270.00
                1 pc Angle Bar, 3(/16) 3.5mm x 1 x 1 x 6M 312.00
                1 pc Angle Bar, (3/16) 4mm x 1 x 1 x 6M 358.00
                1 pc Angle Bar, (1/4) 5mm x 1 x 1 x 6M 443.00
                1 pc Angle Bar, (1/ 3mm x 1-1/4 x 1-1/4 x 6M 377.00
                1 pc Angle bar, (3/16) 3.5mm x 1-1/4 x 1-1/4 x 6M 434.00
                1 pc Angle Bar, (3/16) 4mm x 1-1/4 x 1-1/4 x 6M 482.00
                1 pc Angle Bar, (1/ 2mm x 1-1/2 x 1-1/2 x 6M 294.00
                Angle Bar, (1/ 2.5mm x 1-1/2 x 1-1/2 x 6M 346.00
                1 pc Angle Bar, (1/ 3mm x 1-1/2 x 1-1/2 x 6M 395.00
                1 pc Angle Bar, (3/16) 3.5mm x 1 1/2 x 1 1/2 x 6M 455.00
                1 pc Angle Bar, (3/16) 4mm x 2-1/2 x 2-1/2 x 6M 505.00
                1 pc Angle Bar, (3/16) 4.5mm x 1-1/2 x 1-1/2 x 6M 564.00
                1 pc Angle Bar, (1/4) 5mm x 1-1/2 x 1-1/2 x 6M 623.00
                1 pc Angle Bar, (1/4) 6mm x 1-1/2 x 1-1/2 x 6M 623.00
                1 pc Angle Bar, (1/ 2.5mm x 2 x 2 x 6M 443.00
                1 pc Angle Bar, (1/ 3mm x 2 x 2 x 6M 525.00
                1 pc Angle Bar, (3/16) 3.5mm x 2 x 2 x 6M 605.00
                1 pc Angle Bar, (3/16) 4mm x 2 x 2 x 6M 680.00
                1 pc Angle Bar, (3/16) 4.5mm x 2 x 2 x 6M 757.00
                1 pc Angle Bar, (1/4) 5mm x 2 x 2 x 6M 837.00
                1 pc Angle Bar, (1/4) 6mm x 2 x 2 x 6M 990.00
                Flat Bar, (1/ 3mm x 1/2 x 6M 2.8mm more or less actual thickness 1 pc 70.00
                Flat Bar, 3mm x 3/4 x 6M 2.8mm more or less actual thickness 1 pc 100.00
                Flat Bar, 3mm x 1 x 6M(Red) 2.8mm more or less actual thickness 1 pc 138.00
                Flat Bar, 3mm x 1-1/4 x 6M 2.8mm more or less actual thickness 1 pc 188.00
                Flat Bar, 3/16 x 1-1/2 x 6M 2.8mm more or less actual thickness 1 pc 224.00
                Flat Bar, 3/16 x 2 x 6M 2.8mm more or less actual thickness 1 pc 285.00
                Flat Bar, 4mm x 1/2 x 6M 3.8mm more or less actual thickness 1 pc 90.00
                Flat Bar, 4mm x 5/8 x 6M 3.8mm more or less actual thickness 1 pc 112.00
                Flat Bar, 4mm x 3/4 x 6M 3.8mm more or less actual thickness 1 pc 135.00
                Flat Bar, 4mm x 1 x 6M 3.8mm more or less actual thickness 1 pc 176.00
                Flat Bar, 4mm x 1-1/4 x 6M 3.8mm more or less actual thickness 1 pc 250.00
                Flat Bar, 4mm x 1-1/2 x 6M 3.8mm more or less actual thickness 1 pc 290.00
                Flat Bar, 4mm x 2 x 6M 3.8mm more or less actual thickness 1 pc 370.00
                Flat Bar, 5mm x 1/2 x 6M 4.5mm more or less actual thickness 1 pc 128.00
                Flat Bar, 5mm x 5/8 x 6M 4.5mm more or less actual thickness 1 pc 165.00
                Flat Bar, 5mm x 3/4 x 6M 4.5mm more or less actual thickness 1 pc 205.00
                Flat Bar, 5mm x 1 x 6M 4.5mm more or less actual thickness 1 pc 260.00
                1 pc Flat Bar, 6.5mm x 1 x 6M 325.00
                1 pc Flat Bar, 6.5mm x 1-1/4 x 6M 425.00
                1 pc Flat Bar, 6.5mm x 1-1/2 x 6M 505.00
                1 pc Flat Bar, 6.5mm x 2 x 6M 670.00
                1 pc BI Pipe, 1/4 x 6M s20- N/A 0.00
                1 pc BI Pipe, 3/8 x 6M s20- N/A 0.00
                1 pc BI Pipe, 1/2 x 6M s20 192.00
                1 pc BI Pipe, 3/4 x 6M s20 245.00
                1 pc BI Pipe, 1 x 6M s20 350.00
                1 pc BI Pipe, 1-1/4 x 6M s20 447.00
                1 pc BI Pipe, 1-1/2 x 6M s20 525.00
                1 pc BI Pipe, 2 x 6M s20 720.00
                1 pc BI Pipe, 1/4 x 6M s40 com- N/A 0.00
                1 pc BI Pipe, 3/8 x 6M s40 com- N/A 0.00
                1 pc BI Pipe, 1/2 x 6M s40 com 220.00
                1 pc BI Pipe, 3/4 x 6M s40 com 282.00
                1 pc BI Pipe, 1 x 6M s40 com 388.00
                1 pc BI Pipe, 1-1/4 x 6M s40 com 590.00
                1 pc BI Pipe, 1-1/2 x 6M s40 com 688.00
                1 pc BI Pipe, 2 x 6M s40 com 927.00
                1 pc BI Pipe, 1/2 x 6M s40 std 430.00
                1 pc BI Pipe, 3/4 x 6M s40 std 555.00
                1 pc BI Pipe, 1 x 6M s40 std 855.00
                1 pc BI Pipe, 1-1/4 x 6M s40 std 1,170.00
                1 pc BI Pipe, 1-1/2 x 6M s40 std 1,350.00
                1 pc BI Pipe, 2 x 6M s40 std 1,810.00
                1 pc GI Pipe, 1/2 x 6M s20 250.00
                1 pc GI Pipe, 3/4 x 6M s20 312.00
                1 pc GI Pipe, 1 x 6M s20 450.00
                1 pc GI Pipe, 1-1/4 x 6M s20 617.00
                1 pc GI Pipe, 1-1/2 x 6M s20 707.00
                1 pc GI Pipe, 2 x 6M s20 975.00
                1 pc GI Pipe, 1/4 x 6M s40 com- N/A 0.00
                1 pc GI Pipe, 3/8 x 6M s40 com- N/A 0.00
                1 pc GI Pipe, 1/2 x 6M s40 com 295.00
                1 pc GI Pipe, 3/4 x 6M s40 com 408.00
                1 pc GI Pipe, 1 x 6M s40 com 540.00
                1 pc GI Pipe, 1-1/4 x 6M s40 com 876.00
                1 pc GI Pipe, 1-1/2 x 6M s40 com 925.00
                1 pc GI Pipe, 2 x 6M s40 com 1,255.00
                1 pc GI Pipe, 1/2 x 6M s40 std 557.00
                1 pc GI Pipe, 3/4 x 6M s40 std 720.00
                1 pc GI Pipe, 1 x 6M s40 std 1,110.00
                1 pc GI Pipe, 1-1/4 x 6M s40 std 1,510.00
                1 pc GI Pipe, 1-1/2 x 6M s40 std 1,750.00
                1 pc GI Pipe, 2 x 6M s40 std 2,340.00
                1 pc Plain Round Bar, (3/16) x 6M (3.17mm Red) (0.500 KLS) 25.00
                1 pc Plain Round Bar, (3/16) x 6M (4.16 Green) (0.700 KLS) 35.00
                1 pc Plain Round Bar, (1/4) x 6M (5.01mm White) (1.2 KLS) 50.00
                1 pc Plain Round Bar, (1/4) x 6M (5.61mm Red) (1.5 KLS) 60.00
                1 pc Plain Round Bar, (5/16) x 6M (6.5mm Yellow) (1.9 KLS) 70.00
                1 pc Plain Round Bar, (3/x 6M (6.9mm Blue) (2.2 KLS) 88.00
                1 pc Plain Round Bar, (3/ x 6M (8.6mm White) (2.9 KLS) 122.00
                1 pc Plain Round Bar, (3/ x 6M (9.4mm Yellow) (3.3 KLS) 148.00
                1 pc Plain Round Bar, (1/2) x 6M (10.5mm Blue) (4.0 KLS) 163.00
                1 pc Plain Round Bar, (1/2) x 6M (11.5mm Red) (5.0 KLS) 200.00 200.00
                1 pc Plain Round Bar, (1/2) x 6M (13mm Green) (5.8 KLS) 230.00 230.00
                1 pc Plain Round Bar, (5/ x 6M (14.5mm White) (8.0 KLS) 318.00 318.00
                Plain Round Bar, (5/ x 6M (15.5mm Std.) w/o color (9.0 KLS) 1 pc 397.00
                1 pc Square Bar, 6.3mm x 6M (2KLS) 80.00
                1 pc Square Bar, 6.5mm x 6M (2.20KLS) 90.00
                1 pc Square Bar, 7mm x 6M (2.40KLS) 100.00
                1 pc Square Bar, 7.8mm x 6M (2.6KLS) 110.00
                1 pc Square Bar, 8.3mm x 6M (3.1KLS) 120.00
                1 pc Sqaure Bar, 8.7mm x 6M (3.6KLS) 150.00
                1 pc Square Bar, 9mm x 6M (4KLS) 160.00
                1 pc Square Bar, 10.4mm x 6M (5KLS) 200.00
                1 pc Square Bar, 11mm x 6M (5.6KLS) 230.00
                1 pc Square bar, 11.5mm x 6M (6.25KLS) 260.00
                1 pc Square Bar, 12mm or 13mm x 6M (8KLS) 460.00
                1 pc Square bar, 16mm x 6M (18KLS) 690.00
                1 pc MS Plate, 3.0 mm x 4 x 8 2,350.00
                1 pc MS Plate, 4mm x 4 x 8 3,100.00
                1 pc MS Plate, 5.0 mm x 4 x 8 3,850.70
                1 pc MS Plate, 6.0 mm x 4 x 8 4,620.84
                1 pc MS Plate, 8.0 mm x 4 x 8 6,161.12
                1 pc MS Plate, 10 mm x 4 x 8 7,701.40
                1 pc MS Plate, 12mm x 4 x 8 9,241.68
                1 pc MS Plate, 14mm x 4' x 8' 11,108.69
                1 pc MS Plate, 16.0 mm x 4 x 8 12,695.65
                1 pc MS Plate, 18.0 mm x 4 x 8 14,282.61
                1 pc MS Plate, 20mm x 4' x 8' 15,869.55
                1 pc BI Sheet, 0.4mm x 4 x 8 (CRS) 440.00
                BI Sheet, 0.5mm x 4 x 8 (CRS) Actual Thickness .35mm 1 pc 500.00
                BI Sheet, 0.7mm x 4 x 8 (CRS) Actual Thickness .58mm 1 pc 575.00
                BI Sheet, 0.9mm x 4 x 8 (CRS) Actual Thickness .80mm 1 pc 765.00
                BI Sheet, 1.1mm x 4 x 8 (CRS) Actual Thickness .94mm 1 pc 1,000.00
                1 pc BI Sheet, 1.5mm x 4 x 8 (CRS) 1,300.00
                1 pc Mild Steel Plates, 3' x 8' Not Available 0.00
                1 pc C Purlin, 2 x 4 x 0.6mm x 6M 250.00
                1 pc C Purlin, 2 x 4 x 1.0mm x 6M 370.00
                1 pc C Purlin, 2 x 4 x 1.2mm x 6M 450.00
                1 pc C Purlin, 2 x 4 x 1.35mm x 6M 560.00
                C Purlin, 2 x 4 x 1.5mm x 6M 1 pc 605.00
                C Purlin, 2 x 4 x 2mm x 6M 1 pc 785.00
                • mbien19
                  mbien19 commented
                  Editing a comment
                  Sir, saan po yan sa Manila nakuha itong price list? Need ko ng " Plain Round Bar, (5/16) x 6M" Ty
              • #68
                Hey NTD,
                Thanks for posting/sharing this lengthy price list of metals. This will be beneficial to most members who are into metalworking for they will have some sort of basis for comparisons since metal prices differs from area to area or province to province. Thought its not totally complete, hehehe, wala pa yung stainless steel assortments, checkered plates, square and rectangular tubings and C-Channels etc etc. But basically these assortments are the usual metals being purchased and used.
                Bro the effort and intention is very well appreciated !!!
                • #69
                  Salamat sir NTD, kinopya ko na agad at prinint para may reference kung gaano kalaki agwat dito sa probinsya.
                  • #70
                    Hey NTD,
                    Hi Rosy,
                    Your welcome! Yeah, that's what I thought. At least anybody who's planning to have WIPs would have an idea of some sort with regards to the prices. And they can adjust accordingly their needs based on their project and budget at hand. Coz that's what came up for me. Some were just to expensive, so have to scrap to projects or look for cheaper alternatives.
                    I'm not selfish. Give chance to others. hahahaha! Sila naman ang mg inquire doon sa ibang metals na wala sa list ko..hehehe! Especially the square and rectangular tubulars. Very useful in making those tables and racks.
                    • #71
                      Your welcome miked! Great. That's exactly the point. So each of us will have a reference of some sort. Hindi tayo maging totally blind kung magkano. We can budget things out accordingly.
                      • #72
                        @ hey NTD,
                        Sana you could have included the name/s of the steel manufacturer where you got these price list !!
                        • #73
                          @ hey NTD,
                          Hi Rosy, It's powersteel. Na entice ako sa magandang video ad nila sa sulit kasi. Especially yung manager, parang si Aubrey Miles look alike. lolz!
                          • #74
                            Salamat Brader. Retail price na kaya yan? Target buy ko is 1/2 S40 BI 6m for my 1/2 pipe clamp. Your price is 220php / 430php.
                            Sa hilera ng T Alonzo, ang ave price is abt 600php for welded type and around 900php for seamless type. I would guess Com means commercial type (welded) and STD might be the seamless type. Threading service is 50php.
                            Saan hardware kaya valid ang price nyan sa Manila? Ako na lang hahanap ng threading service.
                            • #75
                              Bro Ariel, may I suggest avoiding the use of BI pipes, this type of metals rust easily in an instant, mapatakan lang ng tubig, nag kakalawalng na so kailangang alaga pa sa mantika o WD 40, instead get the GI ( GALVANIZED IRON ), it will save you some/lots of hassles in the long run.
