Metals Price Updates
  • #91
    magandang araw po, pahingi naman po price ng galvanized sheet metal. TIA
    • #92
      September 24, 2016 current price
      GI sheet 1.5mm 4'x8' - 1771 per pc
      GI sheet 1.2 4'x8' - 1417 per pc
      GI sheet 1mm 4x8 - 1181 per pc
      • #93
        Mga Sir/Ma'am,
        Pwede nyo po ba kong mabigyan ng pricelist ng mga 'to? And hopefully si Supplier is mejo lapit lang dito South area, I'm from Bacoor. Thanks.
        -Nihon Weld 6013 (1kl)
        -Nihon Weld 6011 (2kls)
        -3x3x1.2 Tubular (2 pcs)
        -2x5x1.2 Tbular (12 pcs)
        -1x2x1.2 Tubular (3)
        -1x1x1.2 Tubular (3)
        -Junction Box (3)
        -Wall Mounted Utility Box (1)
        -2 Gang Switch (1)
        -Panel Board (1)
        -Grey Oxide (1-2 Gallons)
        -QDE Paint (4-5 Cans)
        -3.5mm THHN Wire (30 Meters)
        -Flexible Hose (10 Meters)
        -5/8 x 12in Anchor Bolt w/ Washer (12 Pcs)
        -10mm Rebar (6)
        -12mm Rebar (5)
        -Paint Thinner (1-2 Gallons)
        -# 16 G.I Tie Wire (1 Kilos)
        -4'x8'x1.2 ms Plate (1)
        -Wall Angle (3)
        -Plain Sheet (3)
        -1"x1.2 FlatBar (2)
        -4in Diameter x 1.2 G.I Pipe (2)
        -3in Diameter x 1.2 G.I Pipe (1)
        -2in Diameter x 1.2 G.I Pipe (1)
        -1'x1.2mm Angle Bar
        -10ft x 1.07 Pre Painted G.I Rib Type Roofing (6)
        -Cement (4 Bags)
        -Gravel (.4 Cu)
        -Sand (.2 Cu)
        For fabrication of 1 waiting shed po yan, and I initially have to fabricate 10 waiting sheds.. so sana best price po.
        Thanks!
        • #94
          It would really be best for you to make several copies of these items then check out several hardware stores
          near you, give them a copy each and request for their unit prices on the items stated. They'd be willing to accommodate
          the request for I know this will be some future sales for their store. After getting back the copies, compare each
          item, choose which is the cheapest and that will fit your budget.
          • #95
            Anybody know a shop in Manila or Las Piņas that sells cut size piece of mild steel plate? I really need 3 pieces of 70x70 cm x 6mm ms plate. Also need plasma cutting service. Thanks.
            • Powersteel
              Powersteel commented
              Editing a comment
              Good Day
              Mr/Ms Auther Penn
              You may contact us on the number: ‎731-0000 loc. 111 and look for Aljun Macaraig, for assistance regarding the cut sized mild steel plate.
          • #96
            Hi, just signed up. Ask lng po sana me s price per pcs. ng stainless rectangular tubing 1''x2''x20' & 2''x3''x20'?
            • rhenz16
              rhenz16 commented
              Editing a comment
              Hi, just signed up. Ask lng po sana me s price per pcs. ng stainless rectangular tubing 1.2mm thk 1''x2''x20' & 1.2mm thk. 2''x3''x20'?
          • #97
            December 8, 2016 Price:
            stainless rectangular tubing: type 304
            1.2mm thk 1''x2''x20' = 2, 453/piece
            & 1.2mm thk. 2''x3''x20' = 4, 378/piece
            salesman: daryl
            contact no. : 0906-940-8007
            landline: 731-0000 loc. 117
            • #98
              Sorry, baka redundant, pero baka may price po kayo ng pre-fab steel (galvanized)
              Yung ginagamit sa mga steel parking buildings - particularly floor channel (per piece, per length or per sqm)
              Tsaka source din po, salamat!
              • #99
                Good day mga brader.
                Can I ask for the price of 6 x 2 Rectangular Tube and ano po ba basehan ng price - per linear meter or
                per square foot. Thanks po.
                • Originally posted by Bitoy Construction View Post
                  Good Day
                  Sir/Mam
                  Pde ko po bang malaman ang thickness ng 6x2 Rectangular Tube na inyong kelangan? kuning ko na din po ang inyong email address para kayo ay aming mapadalhan ng isang formal price quotation. Salamat Po.
                  • goog day mga paps..
                    ask ko lang po sino na ka encounter ng bumili ng G.i C-PURLINS 2"x3"xt1.5mm
                    then sa actual thickness nya eh halos wala pa po 1mm
                    nsa 0.80 lang po
                    sabi po ng contactor ko khit saan daw po ako mag tingin wala po ako mkikita na eksaktong thickness ng purlins..
                    • Originally posted by allanel0220 View Post
                      goog day mga paps..
                      nsa 0.80 lang po
                      Hello po,
                      Sir/Mam
                      Regarding po sa GI C Purlin 2"x3" Thickness 1.5mm at 0.80
                      Pde po kayong tumawag sa aming sales personnel na si Sir Aga 09259601752 or 731-0000 loc 153 para sa formal price quotation.
                      Salamat Po
                      • San po ba nakakabili ng 1" x 1/16" Flat bar mga 15" ang haba, nasa magkano ba yun?
                        • Check out junk shops selling scrap steel, they may have some and priced per kilo.
                          Not in regular neighborhood steel stores, usually they sell the standard 20 feet long or 6 mt.
                          __________________________________________________ __
                          By the way, pls do introduce your self, PHM has a Member Introductions at the lower
                          portion of the index page. We just want to know you better being a new member of the
                          forum. You may tell us about your interest or hobby, where are you from.
                          Thanks,
                          • Originally posted by Powersteel View Post
                            Hello po,
                            Sir/Mam
                            Salamat Po
                            hi PS... would you be so kind to give me the current price of the following;
                            - Mild steel flat bar 3.2mm x 50mm x 6m
                            - Mild steel flat bar 6mm x 50mm x 6m
                            - Mild steel flat bar 10mm x 50mm x 6m
                            - Mild steel flat bar 10mm x 75mm x 6m
                            - Mild steel flat bar 10mm x 100mm x 6m
                            - Carbon steel pipe, 50mm dia. x 6m, schedule 40
                            - Carbon steel pipe, 150mm dia. x 6m, schedule 40 (7.1 mm WT)
                            I'll be using above items for my training center. tia
