question: reagarding sa stainless steel
  • question: reagarding sa stainless steel
    noob question po. bago pa lang me nag aaral kasi mag welding just for hubby lang. wala po talaga ako proper learning how to weld tantia tantia lang. ask ko lang pede po bang pang welding yong soldering rod ung prang pang electronics na rod sa mga stainless steel roundbar yong maliit lng na bar lang? ano po bang pina pinang wewelding don?
    you mean soldering lead?
    you might be able to pull it off w/ a butane torch if you clean the stainless well and use flux (aka soldering paste). but in my experience solder doesn't stick very well to stainless. it probably depends on the particular stainless steel alloy...
    but for non-stainless steel soldering works very well. just be aware that it's very weak. and that lead is poisonous. i always use lead-free solders
