Requirements for ironworks and welding shop business?
  • Requirements for ironworks and welding shop business?
    Hi, I'm planning to start my ironworks/ fabrication business and don't know if what requirements kasi magsisimula muna kami sa maliit as 3 employees..gusto ko lng I try at matuto sa marketing plan...and maybe in a long run maging sub-contract ako sa mga malalaking project sa mga building construction....thanks...
    pre, your in the right place, we have lot's of members who are into welding and metal works ... cheers
      anu po ba requirements sa business permit? I will start with limited power tools such cut off machine, oxy ace, weldkng machine,drill press...meron na kasi ko 2 grinder, drill etc...I think pwede na yan para mkafabricate na....into untiin nlng pagbili ng iba pag kumita na...hehehehe...thanks bro
        Bro you will need various metal clamps, more and more tools, a fairly good size flat welding table, enough space for your shop to stock on materials and work on your projects.
        Plus sipag, pasensya at tyaga to attain your ultimate goal !!
        For the business permit, go to your local municipality then go to the office of the budget secretary and
        they will give you their requirements.
        Good luck
        • Boo-Semi-Retired
          Boo-Semi-Retired commented
          Editing a comment
          for the business permit, most provincial municipalities (e.g. south cotobato) has a one-stop office for processing business permits. it's quite easy once you have all the documents ready. first, they will provide you with a list of the documents you need to present to them. then you gather the documents. then you go back to them with the documents and pay the necessary fees ... cheers
        • thugstools_413
          thugstools_413 commented
          Editing a comment
          thanks bro...alam ko kaya ko ito lakas ng tiwala at loob sa sarili...hehehehe
        Location is the number one consideration because it should accessible your business in public place.
        The essential requirements are Baranggay Clearance, Permit from Barangay, Mayor's Permit, BIR Tin Number, BS 5, SSS, clearance from BFP etc.
        It should have a tools that relates to your business.
        When it comes marketing plan, you should create the identity of your business such as history, mission, vision, value proposition etc.
        • thugstools_413
          Editing a comment
          thanks cmorales mga roughly how much oo for requirements fee for the papers? capital ko po mga 60k for my tools...( angle grinder, hand drill, cut off machine, welding machine, Oxy ace, clamps, adjustable wrench, tape measure, try squares, level, at mga consumables etc....anu po ba kadalasan pinapagawa ng mga tao sa mga fabrication and repair?
        You're welcome Bro. Yeah, if you have a garage makakapagsimula sana kayo while you completing the business requirements kahit papaano may kinikita ka kaagad.
        Ganto ginagawa sa fabrication(please see attached).
          san ang location mo bro? Sa probinsya di ganung mahigpit..tama si bro cmorales,in my case nag start lang ako as a hobby shop kalaunan ng marami ng nag papagawa saka lang ako nag expand as fab shop so far di ko pa kinakailangan ang business permit hehe..
          Pag metal fab shop kailangan kung all around ka jan.. From vehicle repair(mostly under chassy) gate and fences,window grills at kung anu ano pa basta related sa metal..
          Sample sa shop ko..
          • thugstools_413
            Editing a comment
            regarding sa pagwelding ng mga sasakyan pinapaandar mo na yung makina habang nagwwelding ka? kasi dito bago kami mgwelding ng part s sasakyan pinapaandar muna nmin yung makina sa Una iniisip ko kung bakit yun pala ay para Hindi madrain yung battery
              wow! bro bugel nice starting...gusto ko rin mgbusiness ng. ganyan gusto ko kahit anu ipagawa kaya kung gawin...actually andito aq sa Saudi building construction firm mostly ginagawa ko rin welding ng mga parts ng heavy equipment dito at concrete panel and installing anchor bolts para sa mga poste at dito natin aq nasanay sa mga maninipis na sheet metal magwelding...kya naisipan bakit di nlng aq gumawa ng sarili Kong shop
                Ei madali na lang sayo brader yan..may back ground ka na sa fabrication at skilled weldor ka..fab skills at konting lakas ng loob lang ang kailangan jan..pag may nag pagawa sayo kahit na di ka gaanung pamilyar sa trabaho tangapin mo saka mo pag praktisan..hehehe..
                Yung pics na projects ko na yan pinag aralan ko lang yan..malay ba nilang pinag praktisan ko lang yan..har har..step by step mapag aaralan mo na yan from dealing with customer to project pricing.
                Regarding sa pag welding sa sasakyan..parang mali yata ang procedure nio jan..kailangan bago ka mag hinang sa sasakyan tatangalin mo muna ang Negative terminal ng baterya para maiwasan ang short circuit .maliban lang kung mayroong cut off switch sa power source ang hihinagin mo nha sasakyan..
                  bro, araw2 ba may ngpapagawa sayo at umaabot nman mgkano yung net income mo minimum? kasi iniisip ko kung kukuha aq ng pwesto o backyard fabrication lang..kasi gusto ko sna maging sub contractor sa mga construction company balang araw...heheheh...mju impossible perk be positive lang tlga at lakas ng loob...hehehehe
                    Yes this is true and the practice here in our country, simply disconnect the terminals from the battery before doing any kind of welding in our vehicles to avoid some sort of battery discharge. Experienced this several times in the past when some parts need some repairs or welding in my vehicle.
                      here in Saudi we keep engine running while welding some parts...no time for removing the terminal from the battery...bka pwede rin dyan saatin maapply ang ganun...hehehehe
                      • Boo-Semi-Retired
                        Editing a comment
                        i don't have any experience in welding but given that there is an electrical current passing thru the welding rod and the metal your welding, it's better to remove the terminal wire to the battery for safety reason, especially the ground wire - it only takes you about 1-2 minutes to remove the wire :-). vehicle battery are normally grounded to the engine block which is isolated from the chassis of the vehicle. as such, when you inspect any vehicle's electrical wiring, you will always see a + and - wire for the connection. so if a vehicle is properly repaired and maintained, the battery terminals should not in any way have any contact with the chassis, which is why, technically, you don't have to remove the battery wires before welding.
                        and that's where the problem is. here in PH, you have a lot of auto shops, for some reason, other shops, when they install a new accessory or do some electrical repair change the grounding of the vehicle. as such, for safety reason, it's better to disconnect the wires from the battery before doing any welding ... cheers
                      Sa status ng shop ko ngayun never ako na zero araw araw..medyo pahinga lang ako ngayun dahil nadisgrasya yung paa ko..sa income mahirap i estimate eh..pero decent naman. Start ka muna sa backyard fabrication..pag malakas na saka ka na lang mag expand..
