I want to fix our bed frame :avmakeinsdustri.es
  • I want to fix our bed frame :avmakeinsdustri.es
    We have half centutry bed frame that need to be repair. Everytime I heard the squeeks I always think to fix this by myself buy the tools that I need eg welding machine and cutting machine I almost think enrolled to Tesda for a welding class by that time. but now Its more than that that I got and its now happen.Thanks God.
    The Problem, using a 1/2 plywood the rubber foot is missing and its now NOT level. Put a wood. not able to cut the wood into small pieces I don't have a saw on the time. Now I got that full range of woodshop saw from handsaw to a full 4HP cabinet saw!
    Sketching the design for cut lists and some precisions.
    This is the foam where hold, I will cut the old legs and replace with the new adjustable one.
    This is the legs that I need to replace.
    It's cutting time
    Layout the materials
    Welding time, the most loved part.
    Time to use the hoppers.
    Dry fitting.
      Welding the nuts
      Fclamp and weld.
        Done. Thanks for Viewing
          That's a cool restoration project bro. I like what you've done with the feet!
            Thanks jantech its the center support. the main feet is still wooden
