MIG welding adventures w/ CIGWELD Weldskil 250 Mig
  • MIG welding adventures w/ CIGWELD Weldskil 250 Mig
    I will be posting new metal projects in the coming days using this welding process
    so watch out. Kinda excited with the new projects in line.
    looking forward to them
      Any updates? I want to venture into this too..... not that I hate my stick welds but I want to learn new things. Long time no post since I started stick welding back in 2012
        Bro if you are really interested in learning how to Mig weld, then go for it, buy yourself
        a Mig machine, its not really hard to lean how to apply the welds, its more cleaner than
        using a stick welder. Only thing is its more expensive compared to a stick welder.
        Plus you have to buy yet a tank of Co2 or a tank of mixed gas (80/20) argon/Co2 as your
        shielding gas, then a roll of Mig wire. Now if its ok with you all this expenses then go go
        for it and enjoy learning the process of Mig welding !
          go for it
          for a while now i've been using flux-core but just recently i got co2 and a 5kg spool of solid MIG wire. i'm still learning MIG but i gotta say that it won't totally replace other welding methods coz MIG has low penetration and i only have the small Cigweld 135 so i'm limited to thin material. but that's also the advantage of MIG, it's great for thin material. today i welded 1.3mm wall pipe w/ MIG, which was pretty much impossible to do w/ fluxcore
          btw if you'll get a MIG machine get one w/ continuously-variable voltage setting. my cigweld 135 only has 4-step voltage control so you can't fine tune it.
