Homemade plasma cutter
  • Homemade plasma cutter
    Will anyone take the challenge and build one?
    http://xa.yimg.com/kq/groups/1333516...SMA_CUTTER.pdf
    Re: Homemade plasma cutter
    why not take the challenge? we will root for you... go go go...
      I'm also thinking of this, but most DIY plasma in the net are high voltage type. I would prefer the low voltage high ampere models for DIY
      So far the only toys I did DIY are MOT welders, MOT spot welders, and a car battery charger.
        You forgot the magic bulb i`ve seen in your place sir..hehe..
          OFF TOPIC: Ahh yun.. Secret powersource yun eh..
            yup. ii already bought the torch. its a panasonic clone. need help, tho. 3KVA transformers are as expensive as hell. im considering doing an inverter. but that also needs a transformer. got some MOT's?
              I get MOT's from junk shops, mostly magbobote carts. Just be careful to diffuse the capacitors, its loaded with high voltage charges. Even if the oven is unplugged.
