Plasma cutting Jig
  • Plasma cutting Jig
    Just sharing my Plasma cutting jig for batch cutting of straight cut on metalsheet.
    my original plan is to make a 8'x4' welding table I bought a 6mm MS plate but the project was stuck due to space and budget.
    so decided to utilized the plate as a temporary cutting JIG
    I placed it on 2 small Bench then weld Angle bar on one of each side of 4' and 8' making sure squared to each other
    a back gauge or material stop by 2 solid round stock ran to a 1 1/4" square tubing 3mm thick 2 set screw to hold the bar in place.
    angle bar serves as backgauge or material stop
    the square tubing parrallel to the angle bar supports the material to prevent sagging while cutting
    the 8' angle bar as side guide
    Re: Plasma cutting Jig
    material feed in place and ready for cuting
    the edge of angle bar served as straight guide
    saves a lot of time on batch job
    sorry for the rust its been raining here for days
      hey bro,
      sorry off topic but I just typed a PM for you but PHM says you cant receive PMs...
        Pwede naman siguro dito anu ba yun?
        Sent from my iPhone using Tapatalk
          Hehe..mag papa plasma cut ka ba ng wood sir V?
          Nice set up bro..ilang mm ang cutting capacity ng plasma cutter mo?
            3/4" pero di ko pa nasusubukan sa makakapal wala naman kasi akong ganun materyal
              Ito yung actual cutting
              http://youtu.be/KSIPp4WABL8
                Ahahay..parang papel lang yung sheet..gusto ko nyan!
                  Dami ko na nga nahiwang tinapay. Mamaya tasty na mga to lol
                  http://youtu.be/lKsO-v4owdA
                    Yes, great jig for your metal sheet cuttings. By the way may I ask what is the HP of your compressor you use for your plasma cutter ?
                    Thanks in advance !
                      Quincy model q13160v
                      3.5hp
                      Ok done na
                      Cutting naman ng square tubig kaso nakita ko na lang basag to guard sa cold saw ko
                      Lumutonv ata sa gamit kong coolant
                        sir ask ko lang anong klase gamit mo sheet metal?
                          Bi po
