steel window
  • steel window
    after done making my dp stand i started to build this four leaf steel window to replace the wire mesh that i barricade in our roughly finished house..
    granting the request of my wife..asikasuhin ko naman daw ang bahay
    materials:
    3 full length Z bar (sub standard) can't find the thickness of my choice
    3 9mm square bar
    1 I beam /bar
    1 T bar
    4 pairs of hinges and 2 pairs of window locks
    here is the main component of my build..the frame..it took me a couple of hours to build this flimsy frame..too thin every time i apply some spot welds the metal warped and started to move off to 90 degree angle..
    [IMG][/IMG]
    Re: steel window
    then cutting full length I beam for the cross member..
    sir rosy i believe that this is the material you use in your current project (saw horses)
    [IMG][/IMG]
    change position..i flipped the metal stock..the machine having difficulty cutting through this I beam..ganito pala dapat..
    [IMG][/IMG]
    after cutting the metal i have to trim each end of I beam like shown in the pic..
    [IMG][/IMG]
    to create a good weld joint..
    [IMG][/IMG]
      Re: steel window
      this is very tedious part..
      [IMG][/IMG]
      lol! pic taken by my wife..
      [IMG][/IMG]
      medyo matigas na ang frame but still shaky..
      [IMG][/IMG]
      then simultaneously cutting 9mm square bar..for speedy and accurate chopping process..
      [IMG][/IMG]
        Re: steel window
        then one by one i started to weld the square bar horizontal to the frame..
        [IMG][/IMG]
        [IMG][/IMG]
        layu layo ang pag lalatag ko ng square bar..i have a feeling that the frame will distort pag sunod sunod ang gagawin kong weld sa square bar..
        [IMG][/IMG]
        [IMG][/IMG]
          Re: steel window
          haha..no effect ang diskarte ko..notice the curve..
          [IMG][/IMG]
          i came up with a solution by putting wooden blocks in each corner then applied some pressure by my own body weight..
          [IMG][/IMG]
          yan diretso na..
          [IMG][/IMG]
          bintana naman..gamit na gamit ang grinder dito..
          [IMG][/IMG]
            Re: steel window
            four identical windows..almost
            [IMG][/IMG]
            i marked the center of the I beam with chalk..this will help me to align the window in the frame.
            [IMG][/IMG]
            aligning the window in the frame..
            [IMG][/IMG]
              Re: steel window
              hinges and locks that i will be using in my build..
              [IMG][/IMG]
              T bar..this will be weld in the middle section of window frame that divide the two glass in each frame thus it will give additional strength too..
              [IMG][/IMG]
              [IMG][/IMG]
                Re: steel window
                slowly but surely i manage to attached the window in the frame
                [IMG][/IMG]
                and now for the locks..
                [IMG][/IMG]
                para mas matibay pag na i mount na sa pader..i we weld to sa gilid ng frame..pakain sa concrete..
                [IMG][/IMG]
                done..
                [IMG][/IMG]
                  Re: steel window
                  [IMG][/IMG]
                  [IMG][/IMG]
                  i was preparing for priming i found out that my compressor is nowhere in my tool cabinet !
                  hiniram nga pala di pa sinosole!
                  kaya to be continued muna..
                    Re: steel window
                    Ayos Bro Bugel ... ganda. Yan ang maalaking advantage mo ... napaka sipag mong gumwa ng project.
                      Re: steel window
                      [IMG][/IMG]
                      [IMG][/IMG]
                      [IMG][/IMG]
                      [IMG][/IMG]
                      Kung minsan bro pag na encounter ko na medyo hirap ang blade nilalagyan ko ng kahoy ( 2" x 2" or appropriate size ) sa me fence para medyo pa gilid ang pasok ng blade.
                        Re: steel window
                        [IMG][/IMG]
                        Yes bugel, you are right, that is the same material I used for the metal saw horse project, its a T-Bar, usually used for steel window casements. I just made use of those excess material from the steel casement window projects made in 2008, sayang kasi, kinakalawang na lang sa garahe.
                          Re: steel window
                          @ sir jay..thanks sa tip..napansin ko lang pag sa malapad na kumakagat yung blade
                          Nahihirapan ng kainin yung bakal..napapansin ko yun pag wala ng spark na lumalabas.
                          @ sir rosy t-bar pala kala ko i beam..hehehe yun kasi ang sabi sa hardware eh..
                            Re: steel window
                            update of my steel window project..without glass..
                            [IMG][/IMG]
                            it"s a combination of pearl white and metallic black..
                            [IMG][/IMG]
                            with glass..
                            [IMG][/IMG]
                            [IMG][/IMG]
                              Re: steel window
                              [IMG][/IMG]
