Bugel's random projects
  • Bugel's random projects
    Bit and tool holder for my drill press
    Scrap square tube..
    [IMG][/IMG]
    Scrap galvanized sheet para sa flooring ng tool pan..
    [IMG][/IMG]
    cut both sides using angle grinder..
    [IMG][/IMG]
    Then bend..
    [IMG][/IMG]
    Re: Bugel's random projects
    Trimming the edges..
    [IMG][/IMG]
    Now for the frame..
    [IMG][/IMG]
    [IMG][/IMG]
    [IMG][/IMG]
      Im using nihon weld 3/32 6013 rod/90 amps
      [IMG][/IMG]
      1.5mm thick nga pala ang square tube..
      [IMG][/IMG]
      I weld 1x1 angle bar in the frame for drill bit holder..
      [IMG][/IMG]
      Spot weld lang para di mag bend..
      [IMG][/IMG]
        Bore a hole according the size of drill bits..
        [IMG][/IMG]
        From 1/2 to 13/64..
        [IMG][/IMG]
        Then flare each hole using straight grinder..para smooth ipasok ang bit..
        [IMG][/IMG]
        [IMG][/IMG]
          Tamang tama ang fit ng magnet sa palikpik ng bakal kaya ito ang napili kong i weld sa frame..
          [IMG][/IMG]
          I choose not to bolt the x-y vise..instead i clamp na lang para madaling magtangal at magkabit,pati pag adjust madali rin..
          [IMG][/IMG]
          Ayan tapos na..
          [IMG][/IMG]
          Nakadikit lang ng magnet hehehe..pero sturdy naman..
          [IMG][/IMG]
            Welding magnet and hammer holder plus some consumables on top..
            This is a way of cleaning your shop and organizing your tool as well..
            To get rid of rusty stuff why not converting it to something usefull..
            Scrap 5mm ms plate..
            [IMG][/IMG]
            Cut according to my preferable size..i use angle bar as a guide..para pag nag trim ng edges mas diretso..
            [IMG][/IMG]
            [IMG][/IMG]
            [IMG][/IMG]
              2x2 angle bar for hammer holder..
              [IMG][/IMG]
              Dahil wala akong oxy/ace..drill press na rin ang pinang putol ko..yung may straight mark hacksaw lang..
              [IMG][/IMG]
              [IMG][/IMG]
              Parang ganito lang ang idea..
              [IMG][/IMG]
                After shaping and drilling..welding time again..
                [IMG][/IMG]
                [IMG][/IMG]
                Konting weld lang para di mag warp..
                [IMG][/IMG]
                Then bore two holes..tox ko lang sa pader to..
                [IMG][/IMG]
                  Done..
                  [IMG][/IMG]
                  After painting..
                  [IMG][/IMG]
                  Kung sa table ko kasi ididikit lang ang magnet for sure mag collect ng metal debris to..
                  [IMG][/IMG]
                    A stand for cutting full length metal stock..
                    Meron na ko dati hindi lang ako nasiyahan dahil laging tumataob yung stand tuwing hihilahin ko ang bakal..konting modifications lang..
                    Scrap office chair/electric fan stand..pinag bolt in ko lang..hehehe..
                    Malaki ang gap kaya nag de flux ako ng 3/32 rod..para naka sentro at madaling i weld.
                    [IMG][/IMG]
                    Pangit ng weld..hehehe..
                    [IMG][/IMG]
                    1x1 flat bar..
                    [IMG][/IMG]
                    Drilled up to 5/8 bit size..
                    [IMG][/IMG]
                      I enlarge the hole using die grinder..then insert 1/2 gi pipe..
                      [IMG][/IMG]
                      I insert another tube again..roller type para madaling hilahin ang bakal.
                      [IMG][/IMG]
                      [IMG][/IMG]
                      [IMG][/IMG]
                        Welding adjustable post in roller..
                        [IMG][/IMG]
                        Nakayari na naman ng isang project..
                        [IMG][/IMG]
                        In action
                        [IMG][/IMG]
                          Washing machine stand..
                          Nakabili ng bagong tool si misis..gawan ko raw ng stand.
                          [IMG][/IMG]
                          Tack weld each corner..
                          [IMG][/IMG]
                          I add extra square tube..para mas matibay..
                          [IMG][/IMG]
                          Eto nga pala yung dati kong stand..laging tumatambling tuwing hihilahin ko ang bakal..
                          [IMG][/IMG]
                            Do not try this at your shop!welding in shorts and slippers may cause severe burn in your skin! LOL!!!
                            [IMG][/IMG]
                            Bad habit..but that was before..hehehe..
                            [IMG][/IMG]
                            After making a full weld..
                            [IMG][/IMG]
                            [IMG][/IMG]
                              Ginabi na ko..
                              [IMG][/IMG]
                              1/2 plywood on top..if the weather will cooperate i'll paint it later..
                              [IMG][/IMG]
                              • Tekinex
                                started a topic Airconditioning guide
                                Hi guys. Im kinda new in this forums but i am in an airconditioning company for a long time.
                                Here is my views and opinions in a/c since it...
                                See more | Go to post
                                Last edited by Tekinex; Today, 01:03 AM. Reason: Ongoing Updates regarding a/c and questions will be entertained
                              • Tekinex
                                started a topic Looking for various materials
                                Im looking for various raw materials for my small projects this summer. Below are the list of raw materials needed.*
                                -Clear Casting Resin...
                                Last edited by Tekinex; 03-20-2017, 03:04 AM. Reason: Will start a small workshop soon if it turns out well.
