Portable welding machine
  • Portable welding machine
    Good day, we are planning to construct a concrete fence with gate.
    I would to ask some advice on what kind of portavle welding majibe should I buy. What brand, ratimg and price.
    I would be using it for the construction of the gate which mostly made of rectangular tube for a midern contemporary look.
    I more thing. Which is better para sa gate. A pillow block bearing or bushing like for the hinge?
    TIA
    Depends on your buget at minimum, visit in quipo diaden 200 amp portable inverter start at P4,500 or maybe least from other shop.
      Again that will depend on the cost you want to spend for a welding machine, its either an AC welding machine or
      a DC welding machine. An AC welder of 250 amps will be a lot cheaper than a DC welder of 200 or 250 amp machine.
      But with a DC welder of heavy duty quality has lots of advantages over the the other one. DC machines can be plugged
      in an ordinary household outlet, saves a lot on electric consumption plus has a soft starting during applications. There are
      lots of portable machines in the market now, before you make a purchase, ask your seller about after sales service and
      warranty, I feel this is very important, you have to know who will repair your welder if ever it gets defective.
      I have two DC welders, one Yamato 200 amps and another is HiTronic 300 amps, now which is better, Its the HiTronic
      brand I find more powerful and more heavy duty not because of the amperage but the brand itself. Yes its a Chinese
      brand and its manufacturer is the one making Riland, Rilon and T&R welding machines, known for making heavy duty
      machine and distributed in Asia, US, and Europe. Haven't had any issues or problem with the HiTronic machine,
      been doing great for almost four years now.
      Buy cheap welding machine, you get cheap and poor quality machine. You get what you pay for, right.
      Now regarding your gate, if its not going to be big and heavy, you can probably use the pillow block, three on each side
      for more strenght to carry the weight of the gate but for large and heavy gates, I prefer the bushing type hinge since it
      will be welded on the posts and the gate itself.
      Cheers and Good luck !
        Sensya na po sa mga typo. Ewan ko bat di ko ma edit yung post ko and parating error.
        Thanks for the info crazy cut and rosy. Budget is around 11k to 15k pero pag mayas mura na guality naman mas maganda. Hehehe
        So 200A will be fine sa plan ko na project?
        Mostly I DIY pag wood working lang but constructing a metal gate will be a challenge.
          Ok bro now at least we know your budget for a welder. Kindly check this out, you can select what will fall under your budget.
          Can be the 200 amps or the 250 amps. May I suggest you get the 250 amps machine, that is less 20% discount pa,
          pasok na pasok sa budget mo. P16,500 less 20%........= P 13,200.00
          Contact GOLDPEAK Tools and Hardware and look for sir Heric (coolmaxheric), also a member of this forum.
          Link : http://www.goldpeaktools.com.ph/prod.../hitronic.html
          Again best of luck !
            Thanks po sir rosy. Dagdag kaalaman na naman to sa akin.
            Been following goldpeak sa facebook for quite sometime na din and naka book mark din sa akin yung web site nya hehehe pati panda manila.
            Just want ro get some opinions from experts dito sa PHM.😊
