Arc Welding Info
  • Arc Welding Info
    ill get down to the point.... im not that good in intros
    Good welding
    Ampere too high
    Ampere too low
    ________
    Re: Arc Welding Info
    Arc too long
    Arc too short
    Travel too fast
    Travel too slow
    ________
      Stick Electrodes
      ex.
      E6013
      E = stick electrode
      60 = tensile strength
      1 = position
      3 = type of material
      Ampere rating for electrodes
      size of electrode x 1000 with 10% approximation
      ex.
      1/8 * 1000 = 112.5A ~ 137.5A
      Essentials in Welding (things to consider)
      Material
      Area
      Electrode Size
      Arc length
      Travel speed
      Welding Angle
      Note
      Welding is a big approximation. Be careful not to overload your machine
      Tips
      It is better to increase cord length (to outlet or breaker) than to increase the length of the welding cable (to electrode holder and or ground clamp)
      For portable welding machines, remember to let the unit rest. Using it for a long time (and jobs whose cross sectional area is large and or cutting) to prolong lifespan, the machines like us humans also needs to rest.
      Hope this helps maybe. Got this info through experience and of course READING.
      ________
        This is also a good read for info on Stick Welding.
        http://www.millerwelds.com/pdf/guidelines_smaw.pdf
          nice SMAW, this is a big unit though
          Ill try to put some info on TIG later if I still have the energy left.
          and miller btw is one of the best if not the best welding machine
          ________
            Nice to know how to read the E6013.
            Thanks Silhouette..
            Will try to approximate the approximates,.,hehehe.
              Things to take note for in Electric Welding
              1) Electrode Size
              2) Electric Current
              3) ARC Length
              4) Travel Speed
              5) Electrode Angle
              Commonly Used Stick Electrode
              A6011 - All purpose stick electrode / 60,000PSI tensile strength / light amount of direty,rusty,painted materials
              E6013 - All purpose stick electrode / 60,000PSI tensile strength / light to medium penetrating
              E7014 - 70,000PSI tensile strength / light penetration / faster travel speed / high deposition materials
              E7018 - Low Hydrogen electrode / 70,000PSI tensile strength / for carbon steel / for submerged metals
              10 High cellulose sodium DC+
              11 High cellulose potassium AC ,DC+,DC-
              12 High titania sodium AC,DC-
              13 High titania potassium AC,DC+
              14 Iron powder titania AC,DC+,DC-
              15 Low hydrogen sodium DC+
              16 Low hydrogen potassium AC,DC+
              18 Iron powder low hydrogen AC,DC+
              20 High iron oxide AC,DC+,DC-
              22 High iron oxide AC,DC-
              24 Iron powder titania AC,DC+,DC-
              27 Iron powder iron oxide AC,DC-
              28 Low hydrogen potassium iron powder AC,DC+
              Polarities
              DC Straight - for high penetration requirement
              Electrode Holder ( + )
              Grounding Clamp ( - )
              DC Reverse - for low penetration requirement
              Electrode Holder ( - )
              Grounding Clamp ( + )
              AC - Alternation
              ________
              Washington Dispensaries
                TIG Welding
                -can be used in most kinds of metals
                *MS, BI, GI, stainless steel, aluminum, nickel alloy, magnesium, copper, brass, etc. etc. etc.
                -high quality and clean weld
                -less to no sparks
                -no slag residue
                -used best in thin metals
                Kinds of tungsten rods
                Shielding Gas
                -shielding gas is used instead of slag in stick welding
                -protects weld area from atmospheric disturbance
                *prevents contaminated areas or blow holes
                Commonly used shielding gas
                1) Argon
                2) CO2
                3) Helium
                never use gas that supports combustion like oxygen as shielding gas
                Additional Information
                Transformer Type (core type) Welding Machine
                lesser initial
                heavy weight
                high current consumption (breaker)
                higher voltage fluctuation
                less consistent output welding
                more sparks
                easier to DIY repair or modify
                more people knows how to service
                Electronics Type (usually inverter type(can reverse holder and ground)) Welding Machine
                higher initial
                lighter weight
                lower current consumption (lower ampere rating 200amps and below can be plugged at house outlet)
                lesser to no voltage fluctuation
                more consistent output welding
                less sparks
                difficult to impossible (excluding electronics engineer or similar) DIY repair and modify
                lesser people knows how to service
                ________
                Yamaha Xv250 Specifications
                  nice tips.. TIG are very versatile and strong mostly used in welding thinner metal tubes like reynolds, 5130 cromo and 7071 like my bike
                  just do it work it make it!:gun:
                    [QUOTE=fake_silhouette;9439]Things to take note for in Electric Welding
                    1) Electrode Size
                    2) Electric Current
                    3) ARC Length
                    4) Travel Speed
                    5) Electrode Angle
                    Polarities
                    AC - Alternation
                    ________
                    -Reverse polarity or DCEP, electrode positive (REP) - has 10% more penetration than in AC application.
                    -Straight polarity or DCEN, electrode negative (SEN) - has the least penetration, welds better in thinner metal.
                    In direct current, electricity always flows from negative to positive. Just like when you turn on your garden hose and the water begins to flow, when you weld with DC, the current flows out of the negative and back into the positive. This makes for a smooth welding current.
                    In alternating current, the electricity flows back and forth from negative to positive and positive to negative on a sine wave. This makes an erratic flow for SMAW, producing more spatter and a more unstable current. I used AC for welding 6011 for a couple of years. The welds were OK, but give me DC anytime.
                    Direct current electrode positive (DCEP) is what we used to call reverse polarity. Direct current electrode negative (DCEN) is what we used to call straight polarity.
                    In DCEP the electricity flows into the tip of the welding rod and concentrates about two-thirds of the heat, which gives good penetration. DCEP is usually used on thicker steels.
                    In DCEN the electricity flows out of the rod, concentrating about one-third of the heat on the rod. Less penetration makes this a very good choice for thinner steels.
                    :boom1:[COLOR="Navy"][FONT="Comic Sans MS"][/FONT][/COLOR]
                      meron ba dito gumagamit ng kobelco e6010 at e7018?
                      cheers
                        I highly recommend going over this thread specially to those with or may be interested in Stick welding ( SMAW ) or TIG welding ( GTAW )
                        OK GUYS, enjoy reading.
