pwede ba magamit 3phase 200v Japan standard tig Ac DC machine sa pilipinas?
  • pwede ba magamit 3phase 200v Japan standard tig Ac DC machine sa pilipinas?
    hi, ask ko lang po kung panu ko na magamit yung tig machine ko galing Japan 3phase 200v at anu gagawin para magamit sa bahay na may single phase 220v...pls. need your advice
    Hi thugstool,
    I'm phil from gensan a newly member. You coud'nt use it direct unto house hold outlet we have 220-240v 50/60 hz single phase. On your case you need a digital phase converter or just a normal converter. On the convert you need to know the rating power of your welding machine capacity requirements to avoid trip offs or it will cause damage either of the two. If i were you buy a machine suited to your needs with a minimum requirements of power supply and enjoy it welding.
    LINCOLN 90 Amp fluxcored mig
    Thermal Arc 400 MTS
    Cigweld weldskill 150 mig
    Awelco 2200 synergic multiprocess migsticktig
    TEC arc F40i inline auto voltage sensing mig
    HPT GM2000 stick welder
    Thermal dynamics cutmaster 82 plasma cutter
    Victor CA2460 cutting torch
    Jackson welding helmet
    • rosy
      rosy commented
      Editing a comment
      @ Hi there Crazy cut,
      Kindly introduce yourself to the forum, PHM has a Member Introductions if you will scroll down the index page. Its just under the OUTSIDE DIY SHACK Forum. Tell us somethings about yourself, what you do for your hobbies or interest. We'd like to know you more as a new member of this forum.
      Thanks,
    • thugstools_413
      thugstools_413 commented
      Editing a comment
      I guess I'll buy a new stuff that suits in Philippines standard...thanks
    • ricofrederick
      ricofrederick commented
      Editing a comment
      hey, crazy cut, how did you connect your lincoln fluxcored mig? i know that lincoln has two 110 line volt? pls help. I have hd 180 lincoln, and afraid to try it without being burned. tnx
    depends on the amp rating of the tig and the max household current that you have. or use a 3 phase genset instead.
      here are the specs of Panasonic tig star wx300 from Japan...anu ba dapat na phase converter dapat ko bilhin para magamit ko ito...I know Japan made are smooth regarding on welding...pls advice me of what spec of phase converter do I need to buy and where can I buy those converter?
        ito na yung machine sayang kasi kung di magamit...gusto ko pagpraktisan ng aluminum sa tig....
          Bro thugstools_413,
          If you are now in the Philippines, I guess you can go to a Meralco branch office and ask around to get the proper and correct reply regarding 3 phase power supply. If its feasible or not for such a connections in your house. For all I know its the big manufacturing and fabricating plants in the country that are involved in large production outputs have these kind of power supply and I think it is also expensive just to have it in your house and I suppose Meralco will not badge in to what you may want.
          I suppose you can get a 3 phase genset at Japanese Surplus, those that import surplus car parts, machinery, air cons or generators etc. I think the suggestion of butch11a would be the safest way to do if you insist and feel that the Japanese 3 phase Tig welder will not go to waste.
          Cheers
          STIHL MS 044 chainsaw
          Dreaming and wanting is good and healthy but working hard for it is better !
          • thugstools_413
            Editing a comment
            I think it is the way to run the machine by Japan surplus genset or step down transformer 220-200 to phase converter...huhu..
          Hi thugstools,
          Since the full power capacity of your machine is 14.5 kva accordingly as stated on the nameplate. All you need to have is at least 20 kva phase converter. One of the wye or delta connectors of philippine made converter "since this is not a digital phase converter" is low voltage compare to the remain two connection hot wire but this is not really a problem when the phase converter kva is much higher than your welding machine. You can check in the OLx for futher info contact the supplier try to search "Rotary 3 phase converter". I think it cost about 30k more or less. Try to check your machine again because i could not determine the 3 phase symbol so puasedly before the 200v or maybe im wrong. Hehehe. I hope this well help you.
          Thank you.
          LINCOLN 90 amps fluxcored mig
          Thermal Arc 400MTS
          Awelco 2200 synergic multiprocess migtigstick
          TEC Arc F40i inline auto voltage sensing mig
          Thermal dynamic cutmaster 82 plasma cutter
          HPT GM2000 tig/stick welder
          Jacson welding helmet
          • thugstools_413
            Editing a comment
            if I'm going to buy a rotary phase converter and connect it on our 220v single and I guess it would become a 220v 3phase, However, do I need a step down from 220v to 200v ahead of a converter?
          here is the specs on nameplate 200v, 12kVa/10.5kw and 3phase machine..mju luma na kakapadala lang sakin ng friend ko...huhu...
            No need. Actually your welding machine was tested to higher voltage for tougher duty or voltage surge. But you have still option to ask the supplier for you voltage requirements without installation of additional 3 phase dry transformer.
            Yes! connection from household 220 - 240v 50/60Hz single phase to rotary 3 phase converter will have an output of 220 - 240v 50/60Hz 3 phase. Additional dry transformer will be after the converter output connection either step up (440v 3 ph) or step down.
              thanks again for our advice sa tingin ko di ko muna magamit yung machine because I'm planning to have a small workshop but someone told me that 200v rated input are capable to run in 220v . kasi meron nman -+10% maximum rated input. but the converter it cost 48k for 20kVa to run my 12kVa rated demand...huhuhu...
                Yeah thats good. -+10% that is standard. A small work shop that's cool dud!
                What keep you busy in your work shop?
                  so far I'm here in Saudi working this is my first hand experience gaining knowledge about fabrication cum welder and after this planning my own shop in my province in bicol but still have no idea what I'm going to fabricate and sell it to market easily...do u have any idea? pls help
                    Check the metal fabrication trend on your place. You may start in basic to general fabrication. Like grills & gates, from mild steel to stainless steel. Water tanks, bumpers & muffler. Auto body repair shop & there will be a lot more things to be done when you have the fashion on it. A good visibilty of your product well encourge customers. So! advertising is a must outside on your shop.
                    Explore your imagination a lot of brighter ideas will coming in.
                    • thugstools_413
                      Editing a comment
                      oh! thats great! many thanks im so excited go home...thanks again and god bless you.
                    wow! got this English translated knob functoin of my machine! Thanks to my friend for selling his Panasonic tig star wx300 I can weld both tig and arc - ac/DC. Now need to hire technician who could make a delta connection from house outlet power supply instead of buying a php 48k rotary converter. I already sent msg to the manufacturer and he told me that 220v can barely handle the power , 230v will shut the machine due to over voltages protection.
                      That's good bro! Keep it up.
                      What would be your first project? Does your machine is a thyristor type?
                      • Tekinex
                        started a topic Airconditioning guide
                        Hi guys. Im kinda new in this forums but i am in an airconditioning company for a long time.
                        Here is my views and opinions in a/c since it...
                        See more | Go to post
                        Last edited by Tekinex; Today, 01:03 AM. Reason: Ongoing Updates regarding a/c and questions will be entertained
                      • Tekinex
                        started a topic Looking for various materials
                        Im looking for various raw materials for my small projects this summer. Below are the list of raw materials needed.*
                        -Clear Casting Resin...
                        Last edited by Tekinex; 03-20-2017, 03:04 AM. Reason: Will start a small workshop soon if it turns out well.
