pls. help me
  • pls. help me
    photo above is my water cooled tig torch since I don't have a water cooler machine for my tig machine I want to use the ordinary air cooled tig torch which is my problem is I can't find a compatible 2 pins socket switch that is bigger than the common 2 pins socket used in philippines
      do anyone knows what todo? meron bang 2 pins adapter ng switch?
        Thugstool,
        Bili ka na lang ng complete set ng tig torch na pang air cooled wag mo nalang gamitin ang water cooled torch masisira yan pag walang tubig. If your planning to tig not more than 300 amps air cooled is ideal.
        I reccomend to visit tools from us in cubao, car tools sa libis or sa eleweld sa pasig rosario dami doon maka pamili ka ng gusto mo. Try to google ang location ng store.
          thanks crazy cut...
            FYI: from other group and the owner of the machine according to them I can use my water cooled tig torch using argon gas alone by not exceeding of 7mins of tig welding and not aluminum application...sabi nila pag ginamit ko sa aluminum mas malaking amperages daw kailangan ko at dapat gamitan ko ng water cooler and also u can use a aquarium pump for water cycle into the todch... hehehehehe....problem solve this application only for advance welding just in case your into in it..
              Sir you can also try sa Caloocan area, I know two shop that has spare parts and can repair welding machines. Yung isa is "Sun Weld", nasa corner ng rizal Ave and 6th avenue, yung isa naman nasa corner sya ng 9th Ave and B.Serrano.
