buying tig welding
  • buying tig welding
    Hi...anong pinakamagandang TIG at swak sa budget na tig weld? Yung pwede rin sa thin aluminum para isang gastos nlng... would noy buy another one pag kailagan ng thin na aluminum
    I checked here in our place this morning merong 200amp na zeweld... i dont know if ok naba to.. ano pala different yung may pedal control at wala... yung sa zeweld kasi nasa torch yung switch
    thanks ^_^
    I don't know what your budget is for a Tig machine but for welding aluminum, you need an AC DC high frequency
    Tig machine. Check out Rilon Tig machines or HiTronic Tig machines.
    Have no idea what a zeweld is, first time to here about it.
    Foot pedal is where you control the output of your Tig torch, others..... switch is on the Tig torch itself which is
    optional for the welder.
    Hope this helps.
      Thank you for the reply sir, im planning to visit manila next week saan ko ba makikita yung best price ng rilon at hytronic? Yung mga 200amp pala na dc lang.. anung limit na aluminum kaya niya e weld? Thanks
        kailangan mo ng AC type of tig machine para makapag welding ka ng aluminum. AC tig machine worth 35k php minimum price. you cannot do a decent weld on DC polarity tig machine on aluminum. try research about aluminum welding
          zerocool ,
          Brad kung DC lang ang bibilhin mo, hindi ka makakapag welding ng aluminum, for mind steel at stainless steel lang yan. You will have to buy an AC / DC Tig machine.
          Link for HiTronic welders from Goldpeak Tools and Hardware. Simply click the Tig AC/DC welding and select from there, the stated price is P38K for the 200 amps but take note that there is a 20% less on their welders. your net price will be P30,400.00 only. Simply call Sir Heric (coolmaxheric) also a PHM member.
          http://www.goldpeaktools.com.ph/prod.../hitronic.html
          Hope this helps.
            Thank you sa reply sir, so AC/DC 200amp is ok na for any thickness of aluminum? Titignan ko na by monday nasa manila ako check ko sa golden peak ive been there before...
