Riland Tig 200P AC/DC
  • Riland Tig 200P AC/DC
    Just bought a Riland Tig 200P ACDC welding machine.
    Specification:
    Rated Input Voltage(V)AC220V15% 1P Arc-Initiating(TIG)H-F
    Rated Input Current(A)TIG:28.2 MMA:43.6 Efficiency(%)80
    Input Frequency (HZ)50/60 Power Factor0.73
    Rated Input Power(KVA)TIG:6.2 MMA:9.6 Protection GradeIP21
    Open Circuit Voltage(V)44 Weight(kg)20
    Current Range(A)10-200 Dimension(mm)498*328*302
    Duty cycle at maximum current60@25
    Features:
    Advanced inverter technology delivers superior TIG performance.
    Triple welding process: TIG AC / TIG DC / MMA (Stick).
    Untouch Start DC TIG operation allows you to strike the arc easily with high frequency,and makes it easy to establish an arc under a variety of conditions.
    Premium TIG Performance:
    - Adjustable AC Frequency Focus the arc cone for precise control.
    - Expanded AC Balance Minimizes tungsten erosion and etching surrounding the weld.
    - Pulse Width, Up Slope and Down Slope Function Adjustable.
    Automatic Hot Start boosts the current during starting to make striking an arc easier.
    2T/4T and Repeat Function Selectable on the front panel.
    Digital instrument for the welding current.
    Remote Control Function Ready! - Remotely controlling your current level with a foot control.
    Auto-Protection against over-voltage, over-current and over-heated.
    Energy Saving - Compared with the traditional TIG machine more efficient.
    Still need Tig Gloves, filler rods, tig finger, argon, regulator... etc.
    For now i can already use it for stick welding.
    Comments and suggestions, be it good or otherwise will be highly appreciated.
    Front Panel of the Welder Full view of the Welder with lighter on top for size reference,
    That is a good brand, enjoy your new toy !!
      Thanks @rosy... will have time to tinker with it on sunday. But sadly for stick welding only.
      Still, its time to start understanding what all those controls mean and what or how they need to be used when tig welding.
      • rosy
        rosy commented
        Editing a comment
        Bro,
        May I know the address you purchased your unit.
        I am more interested with their mig machines.
      Bought the unit in a hardware here in Daraga, Albay. Nasa bicol po ako sir.
        Thank you for the reply bro. Wow ang layo pala, sa Bicol area pa, I thought it was purchased
        here in Manila. Anyway , again maraming salamat .
        • ply user
          ply user commented
          Editing a comment
          No problem sir.
