Magnets! finally found some
  • Magnets! finally found some
    true value trinoma!!!
    Re: Magnets! finally found some
    Looks like ceramic? IIRC, that was the same brand that I saw at True Value Park Square a few years ago, but they were individually packaged then, like this. Interesting that the manufacturer marketing/website considers these to be "impulse buys".
    How about rare earth (e.g., neodymium). Anyone seen these locally?
      had a source of rare earth magnets back then, but the store closed already two months ago. haven't seen them elsewhere other than HK.
        I bought some from a South Korean vendor at eBay a few months back.
        http://cgi.ebay.com/10-Neodymium-Magnets-Disk-2-5-x-3-5-N40-/260680732960?pt=AU_Business_Industrial_Medical_Sci entific_Equipment2&hash=item3cb1c85120
          There's a couple of suppliers in Sulit.com. They can even customize to your specs. I have no idea on the price though. I myself is looking for some to be used as kitchen knives/utensils holder.
            Speaking of magnets, would it be possible and a good idea to embed some piece of steel, say flat bar, in new hollow block (CHB) wall being constructed so that rare earth magnets would stick to the finished wall?
            Maybe screw flat bar to the hollow block before cement plastering, and then just plaster over? Would corrosion be a problem? Being buried in cement inhibits corrosion, like for rebar, no?
            Would the plaster that is over the flat bar be weakened and prone to chip off later, since it is prevented from adhering to the CHB? Especially when magnet is pulled?
            Would rare earth magnets work well through the one inch or so thick plaster?
              Pareho tayo ng idea.
              Here's what I did with the neodymium magnets:
              Ang lakas ng kapit! You have exert significant effort to remove the holder from the range hood.
                Nice project. There is a Handyman where we go for groceries and I've been wondering what I could use them for.
                TIP: Dropping a magnet weakens it.
                  Thanks!
                  I've seen those rectangular ceramic ones. They're perfect for this type of holder.
                    Nifty project!
                    I suppose you don't use that chopping board as a chopping board anymore?
                      @joey81
                      Where did you get your magnets?
                        I found this in **************. the supplier sells and customized different kinds of magnets:
                        Neodymium, Alnico, Samarium Cobalt, Ceramic, Flexible Magnets
                        http://www.**************/index.php/vi...+magnet+manila
                        or their website: www.dstechcafe.com
                        Though if I want cheap common magnets, I go to Divisoria. Different sizes, Different shapes.
                          rare earth magnets sana need ko..round mga 5mm thick by 1 inch...neodymium if meron.
                          tia
                            tia
                            Sir violaine, dun sa ************** link na nipost ko sa taas, may neodymium magnets sila. Pwede pang i-customize.
                              it seemed the post is dead...numerous inquiries and no reply?
