A Poll survey for YAMATO DC Inverter Welder
This is a sticky topic.
  • Re: A Poll survey for YAMATO DC Inverter Welder
    Pm mo si bro heric..(coolmaxheric) sa kanya ako kumuha ng pangalawa kong yamato..
      Ok sir bugel. Thanks.
        May I know what model is this Yamato Welding Inverter? Is this the All Original and Genuine YAMATO IGBT Inverter Welder, 200 Amperes Portable Welding Machine, Dual Knob ARC Force? I'm also interested to buy and join the listing.
          Best for you to do is pm JosephS of Industrialsupply143 for your inquiries, he is the marketing
          sale guy there and also a PHM member. Anyway if you will read the whole thread, cp #s or tel nos. have been posted so just check it out na lang.
          Anyway the Yamato 200 amp DC Inverter has only one knob and I think its the Yamato 300 amp
          DC Inverter which have the two knobs, one for ampere settings and the other one for the
          arc force.
          If sure you will buy one, they give discounts to PHM members.
          GOOD LUCK !!
            Hi @Rosy, Im currently researching for portable weldings right now. Im getting rid of the bulky one.
            Anyway, I noticed there is also a portable AC, which is cheaper.
            http://www.olx.ph/index.php/view+cla...sition,1-14,14
            But the ones that are being discussed here and in your other thread is the DC. Is this the same model?
            http://www.olx.ph/index.php/view+cla...Position,1-4,4
            Are they different? I thought the AC ones are the bulky ones. Anyway, i cant find it in Cebu. Can you post the number that we should call for this? Thanks
              AC and DC welders are definitely different.
              What I have is the portable Yamato AC stick welder. But it is smaller than what is found in your link which is 200amp (yellow color). Mine is only 160am (stainless body). I bought mine in Binondo for around Php3,500.
              I am still using up to now mostly on small projects using angle bars, flat bars, and square bars.
