HiTronic Arc 300 Inverter
  • HiTronic Arc 300 Inverter
    Might as well be opening a separate thread for this weld machine so any information or
    inquiries needed will be posted here.
    The unit was purchased/picked up first week of December from GoldPeak Tools & Hardware, located in Blumentritt rd near Espana in Sampaloc Mla. Its managed and owned by a PHM member as well, coolmaxheric, really quite a very nice young and hardworking guy.
    OK here are some pics of the unit, Though I have not used it really yet in my garage but have tested it at GoldPeak.
    This is the overall front side of the new unit. Looks exactly like the RILAND or Rilon models.
    On the upper left side, you'll see the OC Light Bulb, there's the digital readout box, below that are two knobs, one for the Ampere settings (20-300) and the other one is for the Arc force (1-100).
    Then on the opposite side, you'll see the ARC 300 model and the heavy duty on and of switch.
    The lower portion contains the sockets for the lead cable and for the ground cable.
    Re: HiTronic Arc 300 Inverter
    This is the rear side of the unit with the heavy duty power supply cable.
    The right and the left side of the unit.
    This is the power supply cable that does not have an electric plug. I suppose the purpose of this is to play safe on what kind or type a buyer will attach at its end, depending on the kind of outlets or sockets are used in their area.
      Well, here are what I got from the box aside from the unit itself.
      A large sticker on the welder for users. Notifications and reminders on its up keep and how to use the machine properly.
      A shoulder bag freebie and the Owner's Manual.
      And the two heavy duty cables with their corresponding heavy duty electrode holder and very nice ground clamp.
        Here's the complete set up of the unit without the electrical plug.
        Bro Heric provided me with a free 15 amp plug but when I tried it on my welding socket, the ground prong would not fit so..............
        Got this from True Value, its a 20 amp heavy duty plug that fits perfectly in my welding electrical socket.
          And just for size comparison with my existing YAMATO 200 DC Inverter.
          Nothing so far against the Yamato welder, it is still working fine and smoothly this past days and still enjoying its quality.
          From this photo, one can see the very difference in size of the power supply cable, the Yamato vis a vis the HiTronic.
          This HiTronic machine is one of the Five major products of Shenzhen Riland Industry Co. Ltd, known for RILAND, RILON, T&R, and GOOD in other parts of the world. This particular weld machine, the HiTronic Arc 300 is a single phase machine and has an actual size of 40.8 x 20.3 x 31.5 centimeters and has a weight of 17.5 KG.
          With a 50/60 Hz, perfect for our frequency. With regards to duty cycle, its 100% (A/V) ability to work at 231/29.3 and its 60% (A/V) ability to work at 300/32. Has a Digital display and an Arc force knob as well for current arc. The lead cable and ground cable are 3 meters in length each with good quality, heavy duty electrode holder and a ground clamp. It comes with a one year warranty from the supplier as well.
          Next post will be its innards probably after Christmas.
          Thanks for viewing !!!
            OK, for the benefits of the metal working enthusiasts, I'm undressing the welder to see its innards, the interior parts so we may all be educated/informed. I don't usually do this to a new unit but anyway nothing will be touched or changed so I guess this will not affect the agreed 1 year warranty of the unit. I had time over the weekend to unscrew the shell, be amazed with the innards, took several pics and then attached the 20 amp OMNI brand heavy duty plug.
            HERE GOES :
            Took off the shell of the unit and their it is guys, the Right side and the Left side of the welder. Truly very much different from the 200 amps YAMATO. Just look at those IGBT transistors.
              The Top side, seen from the front and from the rear.
              Well this is just at the back end of the positive socket where the ground cable is inserted. An indication for a 300 amp welder etched on the brass block.
                Well, its the plug installation and getting ready for the weld applications.
                I guess the next postings will be the different usage of welding electrodes and with the application of the "ARC FORCE". This will be quite interesting !
                TO BE CONTINUED :
                • Edgardo
                  Edgardo commented
                  Editing a comment
                  Thanks rosy now i have an idea what's inside of this nice Dc arc welding. cheers
                • isfunkee
                  isfunkee commented
                  Editing a comment
                  sir ok lang ba kahit hindi nakakabit yung ground? yung sa akin kasi Hitronic 200T Arc 3 blue, brown and yellow/green yung wire nya?
                • rosy
                  rosy commented
                  Editing a comment
                  Bro isfunkee,
                  OK lang, when I got my unit the ground wire was already factory tied down sa main cord so I guess there is no need to attach it to my plug. Look at the pics posted above and if you will look closely behind the unit there is no connecting prong for any ground connection. Now I just don't know with other units for 200 amps. Baka yung yellow green wire ang ground wire mo. Hope this helps.
                Thanks for the pics bro. Looks like a clean built DC welder to me.
                  Well bro JayL, I suppose it will really be a clean built DC Inverter, its also made by Riland Industry Co., LTD. Almost the same innards of bro Ossie's Riland, only this one is larger and with more IGBT transistors.
                    Congrats bro. Looking forward for your actual usage reviews. At 300A more commercial users will be interested on this welder.
                      I am curious to that "arc force" thing.
                        Likewise here bro quarxdmz, have been reading infos from Lincoln Electric and Miller in the internet concerning the usage of the "arc force". Usually this "arc force" knob is included in 250 and 300 amps stick welders, really very interesting when it comes to its usage/applications.
                        I'll be explaining it later in the coming posts as I do the reviews on the welding applications.
                        CHEERS !!!
                          Looks like magseselos na si Yamato, Bro Rosy!
                          BTW, I, too, had very good experience with Coolmaxheric.
                            HEHEHE, magseselos ?? LOL, I don't think so, I will still be using the YAMATO from time to time when it is needed for light metal projects. Actually its the Yamato AC welder that is now just gathering some dust and cobwebs inside my tool room. I just enjoy and love using the DC Inverter welders, much much better than the AC Yamato.
                            Actually I've been very busy with this new inverter welder this past days, preparing the materials I will be using for the actual weld applications and reviews.
