Another Stick Welder
  • Another Stick Welder
    This 170A welder is available locally for 5,800 pesos. Italian made. Almost same price as an equivalent Korean or Chinese made welder.
    http://www.awelco.com/
    It's the Hobby 2000 model and you can find it under the MMA menu on the left side of the site homepage.
    Did anybody find a better deal on a stick welder lately?
    Re: Another Stick Welder
    bought my Yamato 160A stickwelder at T. Alonzo St. for around Php3,600 last January.
      I'm seriously thinking of getting one of these Inverter Type Stick welders. Any thoughts on this guys?
      http://www.**************/index.php/vi...elding+machine
        The Powercraft Inverter Stick Welder was not on stock. I needed one asap so I settled for this.
        Power Craft 200A portable welder.
        http://www.**************/index.php/vi...s+Dual+Voltage
        Model No. PWM 6-200B
        Rated output current: 200 Amperes
        Rated input voltage: 220/440 Volts
        Rated Frequency: 60 Hertz
        Rated input capacity: 12.5 KVA
        No load elect'l voltage: 55 Volts
        Rated duty cycle: 20%
        Rated load Elect'l voltage: 26 Volts
        Current range: 70-200 amperes
        Shorted Maximum Current: 225 Amperes
        Suitable welding rod diameter: 2-4mm
        Weight: 27 kilos
        Insulation Grade: F
        Machine Dimension: 41 X 17.5 X 29.5 cm (LWH)
        I got it for around 4.7K
          It id not come with a power cord. I have some left over #12 stranded wires. Will these work? Can I plug it in on a 15A breaker ( household outlet ) ?
          TIA
          Some accessories
          Jackson Electrode Holder 400 pesos
          Blue Eagle Helmet 250 pesos
          Hobart Gloves from amazon.com
            Finally found a good reasonably price ground clamp by Lenco Model EG-300.
            http://i514.photobucket.com/albums/t...ltraco/gc4.jpg
            Hope it improves the machine's performance.
              Found some Cigweld 7024 type rods on sale . Good rods for flat position & high deposition jobs. 60 pesos per kg.
              These are "drag" electrodes, since the core rod burns back within a cone of coating, the correct arc length is automatically maintained when simply dragging the rod along the joint at a slight angle.
                How much is the ground clamp Jay? Having 3 contacts I can see why you say it is better. Unfortunately, I just recently changed the one on my set.
                Also, please explain about the electrodes you found. By "just dragging" do you mean there is not need to maintain a gap, or that you don't have to wave it? Where did you get them?
                  Lenco EG-300 Ground Clamp - 595 pesos
                  http://www.wyler.com.ph/
                  I have not tried the rods as yet but yes there is no need to maintain a gap. These are 7024 type rods.
                  Toolec Inc.
                  633-8918 to 20
                  They are the Thermadyne distributor. I got my 10 year old but unused Victor Oxy Ace Torch outfit serviced by them prior to using it. I just chanced upon the rods. Too bad they did not have the 7014 rods which solidify faster.
                  You mentioned that Stainless Steel rods are good to use too. Which brand and number are these?
                    sayang ano, mas maganda sana ito
                      Mas maganda talaga. Nagkamali nga ako dahil nag tipid ako sa binili ko. DC welder pala mas smooth.
                        ang pagkakamali ay maaari namang itama habang may panahon at kung MAY BUDGET pang nakalaan hahaha
                        pwede mo idispose yung existing welder mo, may kukuha nyan at nag aabang dito hehe
                          On the contrary dito sa ganitong welder ka talaga ma hasa ng husto. Very unforgiving ito so pag lipat mo sa magandang welder petik petik lang. Practice muna ako dito ng coordination skills.
                            tama nga po.
                            gusto ko pa din MIG hahaha
                            pero dapat talaga may Stick Welder pa din - AC/DC na hehe
                            • melchor1025
                              melchor1025 commented
                              Editing a comment
                              Tama po Sir Ossie new lng po ako sa group tama po kayo mas maganda po ang mig may kamahalan lng pero mas quality po ang weld kesa sa stick welding
                            JayL, I also have this powercraft 200A stick welder like yours... works great... I bought it co'z I got tired carrying my uncle's 300A welder (really heavy)...
                            • melchor1025
                              Editing a comment
                              Hi sir clayfigur san po made ang powerhouse pasensya napo newbie lng
