all about Air Compressors
This is a sticky topic.
  • Good evening mga boss!
    Bago lng ako sa thread na to for compressors, bakit hindi ko maview ang ibang mga pictures na pinost niyo?, ano gagawin para maview?, salamat!
    • Bro, sorry about that but its not the member's fault. Its just that Photobucket, this is
      where we store our photos before uploading to the forum for free before, now the
      owner of Photobucket has decided to charge users certain amount per month I think
      and ones paid, that is the time pictures posted will start to appear again.
      • Try nyo na lang lumipat sa tinypic.com
        • Pinag-iisipan ko po itong combination na 'to.
          Compressor: Vespa 2HP 115 Psi, 88 Liters 10 cfm
          Spray Gun: 1.4mm, 1.8mm, Air Consumption: 9.8 CFM/277LPM
          Nagpaplanong i DIY pinturahan yung oto ko. Okay lang kung by section ang pag pintura. Kaya kaya to?
          • Originally posted by jhonaubrey View Post
            THEREFORE MY 2 HORSE POWER 88 LITRE VESPA IS RATED FOR 5.85CFM @80PSI
            ..sir that being said, kaya ba ng 2HP 88L vespa magpagana ng spray gun requiring 9.8 CFM/277LPM? TIA.
            • nararapat lamang na iyong pinturahan ang iyong oto ng buo. aking minumungkahi na mag umpisa ka sa isang maliit na bahagi ng isang bagay, maging ito ay lalagyan ng iyong kompyuter o mga bahagi ng motor ng iyong kapitbahay. sa ganung karanasan ay ikaw ay mahahasa at malalaman mo ang iyong pagkakamali sa mga prosesong iyong ginawa. ito ay payo lamang.
              • Sir just a quick question is vespa compressor pump made of cast iron?
                • May idea ba kayo kung saan makakabili ng hose na nasa oagitan ng brass pipe na malapit sa pistions at auto switch? Yung nagho-hold ng pressure na hose. Yung nasa compressor ko kasi keeps on tearing and even if i cut the damaged end and re-fit it back, uulit lang na puputok, mapupunit or mapuputol kahit hindi pa puno yung tank.
                  • Mga Sir ano poh I recommend nyong compressor pang sandblast poh,??, gaya ng granite lapida..
                    • can anybody point out what are the major differences between the so called "genuine" and "imitation or fake" vespa 2hp air compressors as i am into the hunt for it.
