Metal chop saw for cutting wood
  • Metal chop saw for cutting wood
    Hi. I have just purchased a Hi-tronic 200A welder and a Dewalt Metal Chop saw without even having touched a welder in my entire life (lol) due to the fun i have been getting reading the posts and adventures of our local PHM bakalboys.
    I think I will be cutting a few dozen rebars with the metal chop saw but after that, I would like to use the chop saw like an unsophisticated miter saw. Is it possible? Can I change the abrasive blade of the chop saw into a wood cutting blade?
    Did a cursory research, and I gathered that a miter saw and a chop saw (at least for Dewalt) turns at the same no load speed of 3800 rpm. Arbor size for both is 1 in. (5/.
    So can I use the metal chop saw as a miter saw if i change the abrasive blade into a wood cutting blade?
    Thanks so much.
    NEGATIVE !! A metal chop saw is and was made for metal. For wood its a miter saw or SCMS.
    Please don't invite disaster that you'll be sorry afterwards !
      Aw. I thought I could just change the abrasize blade with a toothed blade for cutting wood, hahaha. Tnx for the info sir Rosy!
        Sir Rosy, could you enlighten us (and all of us who might be benefitting from the info) why changing the abrasive blade of the metal chop saw into a toothed blade for wood is not advisable. Would it be because of blade speed, power, vibration, etc? Thanks!!
