Bosch GKS 190 Circular Saw
  • #61
    pwede ba makahingi sudgestion?ano magandang gamitin circular saw blade 7 1/4 size,tnx
    • #62
      tnx sa reply
      • #63
        hello everyone,
        Hi, am just a noob in this forum and just decided to register... I have an upcoming project for my newly bought house, i intend to do DIY stuff like cabinet etc...., doin some small wood working.. As I'm doing some research about this particular CS, i found out this pinoy site, can you recommend for this tool? I'm am no way a professional carperter... as i read your all inputs it really helps me alot.. Thank you..
        btw, where can i buy that CS disk diablo, forgive me for my ignorance but i think that disk is not the stock disk right (orig) cause i think i will be doing a lot of cutting for my projects and i think i have to buy a CS disk just in advance... TIA...
        God bless....
        • #64
          Hello, I recently bought this saw. It has a free extra 40t blade but the arbor is 25.4mm. How can i use it given the saw's arbor is only 20mm? Do i need to replace the mounting flange? Where can i buy it? Price? Thanks in advance
          • #65
            Large bore blades usually come withe an adapter ring so you can use the blade on smaller arbors. Ask the vendor for that ring.
            • #66
              Thanks joey81. I will contact lazada. Sana ibigay. Otherwise, i might be forced to buy a 60t blade with adapter included. Stock is 20t. I need more tooth for plywood.
              Update : Bought a tungsten carbide 60T from Goldpeak with ring adapterprovided. I can now use the free 40T from Lazada. By the way, Lazada gave me na lang a voucher for the inconvenience. Voucher was enough to offset the price of the blade I bought from Goldpeak. In the end, it was still a good deal.
              • #67
                By the way, Where can i buy the inner flange / washer? I checked the website , it is part 1-619-P06-342. Cost is 212 pesos per website. Made an inquiry in their website.I want to do the innovation shown in this thread so that I can use the more common 16mm arbor saw. Thank you
                • #68
                  The inner flange/washer is 199 pesos in makati. The shop ordered it in bosch. Hopefully to get it by friday.
                  • #69
                    Finally have the washer yesterday. Bought it from Toolcare Master in Bangkal, Makati. Thanks to Paul. If you need the part, you must call in advance because they do not stock it normally. They must order it from Bosch. Medyo mahirap lang mag park sa Bangkal.
                    • #70
                      Originally posted by bryant77 View Post
                      Re: Bosch GKS 190 Circular Saw
                      New blade for my GKS 190, Bosch Optiline 60T with 4 pcs ring spacer (20mm/19mm/16mm/5/8").
                      Need to replace my 7 1/4" Freud blade, hindi na maganda ang cut sa melamine boards....after cutting 100 sheets of 3/4" thk 4x8 boards.
                      BTW, in this picture are the "ring adapters" I was talking about.
                      • #71
                        5/8" is 15.875mm
                        If you're going to modify that flange for 16mm you still cannot use the blades for the US market (diablo, freud).
                        If I were you I'll modify for 5/8" and use adapter rings for blades with larger bore.
                        • #72
                          Hi Joey81,
                          I plan to reduce the diameter of the extra washer I have so that it fits exactly the 5/8" blade commonly available in Amazon. I still have my original washer in case the machining goes awry. Thanks for the advise.
