DIY Wood Kiln - dryer
  • #31
    Re: DIY Wood Kiln - dryer
    @guad,
    PM SENT.... JUST TEXT ME BEFORE THE 15TH.
    • #32
      Hi there sir willyfernando, read your PM, thank you very much !!!!!
      • #33
        Hi sir willy! Very informative indeed. May i know how much was spent on making a dyi kiln? Or is it cheaper if we buy the wood kiln dried? Thank you in advance.
        • #34
          sorry for bumping late. sir willy, i hope you received my pm. be waiting for your reply. ty
          • #35
            Hi josephm,
            I'm sorry for the late reply on your query. As you know, the most important thing is that the wood you plan to use for furniture builds are Kiln dried. If you have continuous use as i do then building a dryer is a more economical and effective way of achieving production quality wood. As per current estimates, a dryer in the size I built cost around 1.5M to 2M per chamber. Mine costs around 1/3 of that as per my last estimate. I am now in the process of building a 40 footer capacity chamber. It will cook around 16,000 to 20,000 board feet of wood per 15 days when operational.
            • #36
              Hi thelast,
              I did get both your email and PM. I replied to you via email from the first day you sent it to me. Pls check if it reached you or not so i may resend it if ever. tnx.
              • #37
                Originally posted by willyfernando View Post
                Hi thelast,
                good day sir, i didn't receive your message. had to check the spam folder to be sure and just found it. be replying later sir. ty for the reply.
                • #38
                  active pa po ba to? sir willy pwede po ba makuha contact number mo? intresado po ako sa drying services.salamat
                  • #39
                    Same sir willy. May I have your contact number for possible drying services? Thanks.
