Plywood Aquarium
  • Plywood Aquarium
    Anyone here who have successfully built a plywood aquarium? I'm planning to make one for my next project and i need some advice on the type of wood and waterproofing and where i can buy my materials.
    Re: Plywood Aquarium
    Hmmm...did you mean a plywood aquarium stand or the aquarium itself?
      The aquarium itself. I'm planning to build one for 200 gallons. I want to know where i can source marine grade plywood and how much it cost. If anyone here has tried it i would also appreciate some tips.
        I think he is referring to the actual aquarium.
        You can a lot of information here: http://www.monsterfishkeepers.com/fo...ects-and-Ideas
          Yes the aquarium itself will be made out of plywood with a front glass viewing panel. Thanks for the info.
            That is not advisable, Wood will leak, waterproofing might poison your fish. But if you really wanna give it a try, use marine plywood.
              Many many years ago I also had an idea to build a plywood aquarium by myself. But I had to quit the idea due to the lack of time. I did my own research and found out a great aquarium producer called Titan Aquatic Exhibits .Currently both my tanks at home are made by them, no regrets.
                KetoFit Canada
                An article setting up the peruser for the much praised Mediterranean Diet condition. Your goals for losing fat will decide how often you practice and for to what extent you continue completing an activity schedule that consumes fat. The main safe approach to achieve one's solid weight is through restorative treatment went for diminishing caloric admission.
                http://www.product4trial.com/ketofit-canada/
                  I'm not actually sure if your plan is quite feasible. Update us if you succeed.
