Car's Morning Sickness
  • Car's Morning Sickness
    I recently replaced my car battery, 1SM Motolite. That was 2-mo. ago more or less, but the past week I have been experiencing difficulty in opening the door through my keyless entry switch, though the light on the switch turns on when pressed. Opening the car with the doorkey will only activate the alarm. It will take about ten to fifteen presses before you can hear the sound that announces that the door is already open. And once you turn on the ignition, you will hear nothing but a "click". It will take another four to five clicks before it turns on the engine. This happens only in the morning. I am dumbfounded. Any suggestion from anyone? suggestions will be appreciated, tnx.
    Re: Car's Morning Sickness
    Go back to the battery dealer and ask him to check the battery while it is still under warranty.
      I sure will, this week end. I still have to look for my receipt. tnx.
        Is your battery maintenance free? Check the date of manufacture on the battery. It should be stamped somewhere on the battery. Usually on the side.
        If you purchased the battery withing six months of its manufacture date then it should be good. If the battery has been on the shelf unused for over 6 months then the battery dealer just sold you a stale MF battery. The problem is that MF batteries already come pre-charged filled with electrolyte. These batteries get stale if unused for months. If left unused for over 6 months the plates on some of all of the cells lose efficiency and fail to either charge or hold a charge for too long.
          It seems like your car alarm is messed up. The starter kill feature could be malfunctioning. Have you replaced the remote's battery? Try to disconnect the alarm module to isolate the hard starting problem.
          BTW
            I don't have much knowledge about it. I normally prefer to visit the Repairing Center in such case. Anyways, BMW cars have long been a sign of quality. At the same time, they are considered among the best not only in terms of technical characteristics and reliability, but also in matters of security. Specialists of the organizations "IIHS" and "EuroNCAP" conducted tests on the safety of cars http://www.carzaamin.com/ from the BMW model range, on the basis of which the experts named the best. First place in the ranking took BMW 5-Series. This car has excellent frontal protection and increased durability of the body, and the system of electronic assistants helps to maintain the correct distance and warns about the presence of road signs. Thanks
