DIY Givi Box Bracket
  • #16
    Re: DIY Givi Box Bracket
    please take proper precautions when spraying urethanes..those most often than not contain isocyanates. Pretty dangerous stuff from what i've read..
    • #17
      thanks for the info moji. i really appreciate your concern very much.
      primered:
      • #18
        my paint mixing glass:
        • #19
          • #20
            removing the orange peel/flattening the base coat.
            • #21
              after the top coat:
              w/o flash:
              with flash:
              • #22
                w/o flash:
                with flash:
                im thinking if im going to wet sand and buff the top coat or not
                hmmmmmmm
                • #23
                  decided to finish the procedure hehe
                  wet sanding:
                  my polisher: im using variable speed angle grinder.
                  warning: not recommended to high rpm angle grinder:
                  • #24
                    using 3M rubbing compound:
                    somebody said that you can apply wax after a week, but i decided to apply it after the rubber compound buffing process
                    using Turtle Wax:
                    after wax application:
                    w/o flash:
                    with flash:
                    • #25
                      w/o flash:
                      with flash:
                      • #26
                        Originally posted by ossie View Post
                        the part that i dont like hehehe wet sanding.
                        sir ossie, gaano katagal papatuyuin ang base coat before i can wet sand it?
                        • #27
                          Nice job! I especially like that bender, I've got to make me one of those.
                          • #28
                            i usually wet sand the base coat (even the primer-if needed, and the top coat) the following morning, but sa instruction pwede na sya within 5 hours yata hehe
                            thanks master handyman, yup, the bender is really helpful, a must for a metal worker like us
                            • #29
                              nice bracket sir.... nicely done... one thing lang boss
                              im kinda worried about the strength dun sa may pinagturnilyuhan =)
                              same issue i had with my fabricated givi bracket...
                              dalawang beses naulit na tinibayan yung connection / weld
                              dun nag fail din sa part sa dulo.. where the round bar meets with the hole kung saan nakaturnilyo..
                              or maybe i just carry too much or ride really hard =\
                              • #30
                                w/o flash:
                                with flash:
                                i post mo sa mcp yan sir
