Simulation Program for a 4D Normalization Process ...
  • Simulation Program for a 4D Normalization Process ...
    I'm not sure if this is the right place to post this new topic :-) ... cheers
    Wow! I have no idea what it means Even google can't reply on it properly. If you interested to get additional hints on web design or card games let me know. Cheeers!
      I'm currently doing the UAT (user acceptance testing) of the simulation program i created for the 4D normalization process, specifically for the PH setting as its much simplier than the other 4D's i have seen in other countries ... what i really wanted to do for this article is to document the things that i have learned while developing the system without giving the information i considered to be IP (intelectual property) as the possible uses of the logic and the process i have created also has other possible uses in other application system ... i'm just preparing the outline of the things i want to share in this article, so just bear with me as i'm just one person :-) doing all of this in my spare time ... Cheers
      • Boo-Semi-Retired
        Boo-Semi-Retired commented
        Editing a comment
        Normally, when you develope a new application system, who ever will use the system will provided you with the specification and all the information that you may be needing in able to create the application system.
        But for this type of simulation program, there is no specification to begin with :-) ... you practically have to start from nothing and the only information that you have on hand is your knowledge of statistics and how in general a normalization process should work ... well plus the result of the 4D draws from the historical data ...
      • Boo-Semi-Retired
        Editing a comment
        Why I got interested in doing this simulation program in the first place?
        When i entrolled in a tesda SMAW training here in south cotobato last May 2018 (take note of the date :-), its that long already) almost all of my fellow trainees and even my instructor have nothing to discuss during our training but 4D and how they almost got it right :-) ... being a system guy and quite familiar with probabilities from the many application system that i have done and maintained while working in a financial institution, i ask them from time to time, how are they able to determine the forcasted 4D that they are betting every draw ... most of them will say, they just guess the number to bet or its their special number or whatever ... others have their own simple system of tabulating the stats they they are maintaining ... i kept telling them, if that is the way your doing it, then the only way to win in 4D is because of luck ...
        But then, sometime arounf i think May 18 or near that day, the result of the 4D was a quadruple 5 (ex. 5555) and when i check the PCSO website i notice that a lot won for that result ... and then further reviewing the past results, i notice that in every draw there will always be a small number who always win ... its hard to find a draw date without a winner ... so i made an assumption that maybe someone has already found a data model that is able to simulate the normalization process of a 4D game ... it makes sense up to now for me ... so i told myself, if others can do it, then i can also do it since i am also quite familiar with the normalization process so i said to myself how hard is it for me to develope my own simulation program of the normalization process? ...
        That is the main reason why i got interested in doing this project :-) ... Cheers
      • Boo-Semi-Retired
        Editing a comment
        I think the best way to start this article is to give an overview of the normalization process. i'm not a mathematician so i'll try to best describe this process based on some of the application systems i have encountered in the past ...
        the next item will be on the knowledge base that you need in order to understand the normalization process like the concepts of probabilities, permutations, combinations, counting numbers ... if your line of work is related to actuarial statistics (ex. those who manage systems related to how to compute insurance premiums for such things as just 1 airplane ride - they pay you a certain amount in case that airplane ride crush and you die :-) he he he) then all these should already be familiar to you ... cheers
