REBARS inside poured concrete !
8 Users
Re: REBARS inside poured concrete !
Yup, I reckon I'll be doing do that, consult with a structural engineer on what's the best remedy for that beam and how to repair it. Anyway, I am not pushing this but just want to know, will fixing the rusted rebars without the load work ? Like cutting that rusted portion then re-welding a new piece then covering it up with new plaster.
Just curious here and simply trying to get some other options !! :confused:
Posted : 24/04/2013 2:04 pm
horge
(@horge)
[COLOR="Red"]cutting that rusted portion then [COLOR="red"]re-welding a new piece then covering it up with new plaster
Not with a RC beam, and especially not with its bottom bars.
Add. Never subtract.
As I described above: if (after cleaning) the steel is revealed to have thinned out
too much, you're better off splicing new bars to the old, using lots of #16 GI wire
to try to get back to the original-design sectional area of steel.
Posted : 24/04/2013 2:14 pm
HI there bro horge,
You beat me to your post earlier and didn't see it, before I posted mine but really hoping that you chime in on the matter, but there you are with your suggestion, thanks brother for your post. I will read it again very carefully and also check the link you posted.
Again thank you bro !!!
Bro horge,
Just checked the link you posted and saw the same problem encountered in the various pics, so do you think I have a chance to be DIYing it my self following your earlier suggestions before it gets too late ???
Posted : 24/04/2013 2:35 pm
horge
(@horge)
Bro horge,
In your shoes, I'd repair the RC slab. At least you'd get a feel for how to do
similar repairs in the future. It seems an amateur-level kind of repair, given
the type of RC member involved (suspended 2-way RC slab).
The RC beam is another matter. The only way to assess how bad it is, is to
expose more steel than is presently-visible, and (of course) have the training
to assess how bad it is.
I can't tell how bad it is from just a photo. The corrosion could be localized
and thus repairable, or it could be widespread but hidden under concrete
that's just about to spall next. It could be a DIY job ... or it could be strictly
for a professional. You could play safe and get a pro to take a look.
Posted : 24/04/2013 3:30 pm
latest_idol
(@latest_idol)
IMHO: you can apply rust converter at those rusted rebars, apply a primer, and lastly plastering/cornerings..
Posted : 29/07/2013 4:55 pm
