stainless steel materials
12 Users
(@spyghost)
Re: stainless steel materials
you got a phone of these shops?
Posted : 04/01/2010 10:49 am
Just adding a little info on stainless steel.
Type 202 - general purpose stainless steel. Usually ginagamit sa mga railings ng mall, building at houses.
Type 304 - the most common grade, usually ginagamit sa food industry like stainless steel kitchen ng mga fast food. A little bit pricey compare sa 202.
Type 316 - the second most common grade (after 304). Ginagamit din sa food industry most application sa industrial. High resistance in corrosion.
Corrosion? Yes. Kinakalawang po ang stainless steel 202 at 304. Lalo na pag nalagyan ng muriatic acid even the fumes of acid can corrode the material .
Caustic Soda or baking soda ang pwede gamitin panglinis to neutralized the acid. Use scotch brite or 3M abrasive sponge to remove the rust and wash it with water.
Posted : 17/09/2010 8:53 am
Nice info bryant77.
So the 202 is what most shops offer then? What is usuallly used in pipes?
Posted : 17/09/2010 10:45 am
Nice info bryant77.
202 and 304 are common sa mga tindahan ng stainless steel. For threaded pipes and fittings T304 ang ginagamit.
There are several finishes on stainless steel. Mirror, Satin, 2B and hairline are the common one.
Stainless Steel best joined using TIG Welding.
Posted : 17/09/2010 11:18 pm
Page 3 / 3
