Waterproofing a cement roofdeck
43 Users
(@vc.masterbuilders)
hello
kindly call us for more info.
2881599
Posted : 23/07/2018 9:21 am
(@qopia985)
Regal Keto A seven-day cabbage soup food plan could be very effective in losing as a minimum 10lbs, which are past the scope of this precise article, capitalism sprung into action to satisfy the demand for a option to the problem of our increasing weight. The end result became a plethora of exercise programs and fad diets that took gain of the nebulous nature of vitamins to persuade people that each new weight loss plan that got here alongside changed into, in truth, the first-rate one.
https://greenlifenutrition.org/regal-keto/
Posted : 27/08/2018 2:25 pm
(@oragon)
What is the best type of finishing in roof deck with waterproofing membrane?? tiles or vinyl etc. please kindly advise
Posted : 30/08/2018 2:49 pm
(@jerrydad)
Try this one....
residential roofing contractor
Posted : 31/08/2018 6:18 pm
(@waneywey)
Good day Sirs, after all of the above mentioned water proofing applications, which is best and for long term application? Or is there new products for water proofing.?My roof deck is leaking, i'm planning to remove the topping cement and tiles and apply water proofing before installing tiles again but i need a waterproofing product that has good integrity and can be topped off with cement/tiles, please advise. Thanks
Posted : 21/09/2018 3:44 pm
siradri11
(@siradri11)
Ideally for roof decks, you should go with ceramic tiles because it is more durable than vinyl. Vinyl tiles are more fore interior. I suggest you check this out for further information: tiles price philippines
Posted : 25/09/2018 1:31 pm
(@damion13)
Hey guys, I wondered What best metal detector do you guys use to find those dumps underground? What is the best one? I assume you want one that it can detect deeply into the ground? Now you can choose the best one from detectorall. There are many kinds of metal detectors for sale, and customize the one you want.
Posted : 28/09/2018 5:35 pm
(@fred42)
We have a 400 meter concrete roof deck that is leaking after heavy rain..Ive looked at the cost of water proofing products in silly 4 liter cans and the cost IMO is prohibitive!
Ive been in the construction trade most of my life and I like to experiment!
I bought a 25 KG Mondo skim coat liquid.. This liquid is 100% acrylic. Ive used it a lot before to mix with cement for rendering walls.. This cement additive leaves zero cracks and is impressive.. 25 Kilo tub is 1,350 PHP.
So I pour 1/4th of this acrylic liquid into another 25 kilo tub and add double the amount of portland cement..To this I mixed in half a cup of Sika cement waterproofer (same as Sahara cement additive) and a tablespoon of cement plasticiser.. Add 1 liter of water and mix for 3 minutes with a drill and spiral mixing arm..
I wet a portion of the Concrete deck and applied a weak mix of PVA adhesive and allowed to dry.. I painted a 2 MM coat of my DIY mix and left in in hot sun to see what would happen for 5 days.
Not even a single hairline crack thus far.. I will wait for a month or two to see if it keeps performing..If it does (and I think it will) I will treat the whole deck and save lots of money!!
Posted : 07/10/2018 9:30 am
(@raja22)
A perfect terrace waterproofing in Vashi should be able to resist leakage during heavy rainfall and provide protection against heat loss during summers/winters. The terrace waterproofing solutions improve the standard of your life by helping you incorporate open living spaces.
https://www.raja-n-raja.com/
Posted : 16/02/2019 1:31 pm
Page 6 / 6
