Building a Phil The...
Building a Phil Thein Baffle
14 Users
Re: Building a Phil Thein Baffle
That was quick!
If may suggest, adding a weather strip inside the groove that mates to the lip of the the can will improve the vacuum. Also put something heavy on top, or maybe some rubber straps, to make the lip fit snugly into the weather strip.
In this picture from Phil's site:
His entry nozzle has the outer part of its circumference cut off. I suspect this has a good effect.
How much debris transferred to the shopvac?
no need for a weatherstrip, it is air tight, blew air in and bubble tested. as for the transfer, the filter I am using is bag type, cant confirm how much yet, will try tomorrow. my first baffle could separate approx 98++%... the filter stays very clean...
Posted : 18/05/2010 5:53 am
bbn
 bbn
(@bbn)
Joints do not necessarily seal the same in different pressure directions. The problem with vacuums is that it more difficult to find leaks since you'd have to be inside the vacuum chamber to see the bubbles. The application seems forgiving so I guess it is ok. I'll definitely build one.
Does the container really have to have inclined sides? How about straight sides? Or maybe a plastic drum with concave sides but with some kind of vertical baffle to have inclined sides of sorts?
Posted : 18/05/2010 6:02 am
the ideal container is metal with straight sides, it is easier to build the baffle that way. a concave container negates the baffle effectiveness if you cannot make the baffle touch the large side to the container wall. inclined sides are easy to adjust and opens better since the top would have more room...
Posted : 18/05/2010 6:09 am
the very first PT baffle I made was a plastic container for pool chemicals, it does tend to collapse when you clog the hose... btw, it still works and now belongs to Jay....
Posted : 18/05/2010 6:10 am
bbn
 bbn
(@bbn)
Thanks timber. Those metal cans they pack lard in come to mind. Since this is not your first, I'll take your word for it. Hmmm ... I wonder could the space under a TS have a PT baffle built-in?
Posted : 18/05/2010 6:15 am
actually the mod I see for it is another curved pipe on top so the hoses can pass sideways but enter straight. that way you can mount the shopvac on top with a jig or hide the first stage(PT baffle) filter under the table...
Posted : 18/05/2010 6:21 am
It works so effectively that I never thought to upgrade it with a metal can.
Posted : 18/05/2010 8:17 am
the reason why a plastic can isn't ideal is bec., when the hose clogs from a big piece of paper or plastic or anything that can seal the hose, the container will collapse. even this short thick container I use now still does collapse (which also means it seals well).
just to try it out... I made dust. started by cleaning the shopvac container... there is light stained dust at the bottom...
ran the shopvac with the PT baffle(which I emptied too) in line, and after several minutes... it has about 8 cups of dust in it.
I am not sure if this is 98% but it seems like 99.7% or better...
Posted : 18/05/2010 11:20 pm
The shop vac ( w/ the PT baffle ) I have collect dust I say within that percentage too. The main cleanup job is more on blowing compressed air on the vac filter to clean it of heavy fine dust buildup which tend to decrease suction efficiency.
Posted : 19/05/2010 2:25 am
shopvac has a bag option Jay, it is what I use now and is better with a 10 or 5 micron filter capability iirc, saves the filter way much better and saves the motor by 10 folds...
Posted : 19/05/2010 2:53 am
What's a bag option?
tks
Posted : 19/05/2010 4:01 am
brain dead question. what happens if i just yank out the filter in my shopvac? it will still suck right?
Posted : 19/05/2010 10:09 pm
yes Ben, it will but whatever dust that gets into the vacuum has a tendency to get to the motor too...
Jay,
here is the bag option...
installed...
then I chose a simple cloth filter that shopvac also carries... make the motor work less...
Posted : 20/05/2010 12:08 am
I'll check this out when I visit Binondo again. I hope there's one that will fit a Hangup Pro model.
Have you noticed a real performance improvement on the PT baffle when you switched to a metal can?
Posted : 20/05/2010 1:03 am
the improvement isn't much on efficiency. its just that I tend to get big pieces clog the hose often that collapses the plastic container. even this short thick one I am using collapses...
Posted : 20/05/2010 1:13 am
Page 2 / 4
