Deluxe Router Table...
Deluxe Router Table build
15 Users
chisel
(@chisel)
Re: Deluxe Router Table build
@chisel,
just making things great!
any new projects bro? anyway what is the diameter of your dc port?
thanks
No WIPS No Workshop eh anyways the diameter is 2 1/2 sorry for the late reply.
Posted : 15/05/2011 11:41 am
chisel
(@chisel)
hi chisel,
what do you use to seal the mdf? is it sanding sealer? thanks
Just lacquer bro.
Posted : 15/05/2011 11:42 am
chisel
(@chisel)
Just a tip for those who are building RT Table that uses Triton, Just finished my dust collector ,, before I rely on this for dust to funnel out.
But recently discover that you have to trust the engineer of Triton for dust collection. Use your built in dust collector as it collect almost 97% of dust especially when mounted on the table.
Posted : 15/05/2011 12:01 pm
chisel
(@chisel)
No Dust at all with this kind of setup.
But I will be needing dust separator to lengthen the life of my filter.
Posted : 15/05/2011 12:02 pm
chisel
(@chisel)
The design is very effective that both the router and the fence suck dust effectively.
And if the fence is out of the router for example rabbet cuts, just close the fence and it will create a vacuum that suction is 100% diverted to the router.
Posted : 15/05/2011 12:03 pm
very nice brader, seems like you made good raising the step-down to be housed in the cab... is the triton water-proof:smoke::smoke::smoke::electricf:
Posted : 15/05/2011 2:51 pm
kakinis pa din ng pinnacle plate mo bro! anu ba secret natin jan?:)
Posted : 16/05/2011 4:44 am
chisel
(@chisel)
Secret don't use the router table or if you really can't avoid using it don't let the material touch the pinnacle blade that the secret of a scratch less pinnacle plate ....:p....
Posted : 16/05/2011 12:40 pm
(@lhannz04)
This is how I approach the fence, make a rabbet on the front fence.
Cut a 4” diameter hole for the opening.
Join the base and front fence and to add stability glue some braces.
Sir forstner po ba pinang butas dito? thanks
Posted : 24/08/2011 9:12 am
chisel
(@chisel)
3" holesaw lhannz04
Posted : 24/08/2011 9:34 am
(@ady_doi)
good day! newbie here!
can i ask for the measurement of your router table sir?my father has a router(makita 3600)..just want to make a table for it..some thing like a gift for him..:)
thanks..
Posted : 26/08/2011 4:48 pm
thanks..
can you be specifc on the router? is it a Makita 3600BR or a 3600H?
kung 3600H (D-handle) kasi I would recommend not to put under the table....
Posted : 27/08/2011 12:29 am
(@ady_doi)
oh i see.. it's a 3600H sir.. so, it will be on the top of the table?any of the member here has the D-handle put it in the table?thanks for the reply
good day!:thanks:
Posted : 31/08/2011 9:14 am
good day!:thanks:
I use to have that exact router model, though you can mount it for rt use, it is almost impossible to adjust it under the table. goodluck:apple:
Posted : 31/08/2011 12:28 pm
chisel
(@chisel)
Since the arrival of my scms I was motivated to finish the router table.
This was laying around for months.
Decided to install it to the table on with the SCMS.
Cut to length…
Made groves to the counter top.
Posted : 12/12/2011 9:09 pm
Page 10 / 12
